November 24, 2024, 12:32:09 00:32
Author Topic: PICC PRO for PIC32 Not Working in HI-TIDE  (Read 5872 times)
solarwind
« on: December 01, 2008, 01:32:23 01:32 »
Hey all,
I installed both PICC for the PIC 10/12/16 devices AND PICC for PIC32 both in evaluation mode. Then I installed HI-TIDE. I did the same thing on two different computers. In both cases, HI-TIDE only recognizes the PICC for 10/12/16 compiler set. I can not see the PIC32 toolchain anywhere in HI-TIDE. This is happening on both computers.
OS: Windows Vista, the other computer: Windows XP
Using latest HI-TIDE and latest compilers from HITECH.
Is anyone else having this problem? How can it be solved?
FriskyFerret
-Given: 513
-Receive: 360
Put it in, take it out.
« Reply #1 on: December 01, 2008, 02:04:35 02:04 »
Since neither are cracked versions, perhaps this question would be better asked in the Hi-Tech forum at their website.
solarwind
« Reply #2 on: December 01, 2008, 02:17:04 02:17 »
Well, has anyone else had luck with this? I've tried it on three computers now. Also checked the compiler's directories. In both the PICC and PICC18 install directores, there is a hi-tide plugin directory. But I found no such plugin directory in the PICC32 install directory. This could be why. Now why isn't the PICC32 installer installing the plugins?
-Receive: 21
« Reply #3 on: December 03, 2008, 04:57:57 16:57 »
PICC PRO for PIC32 Not Working in HI-TIDE is ok.
why not?
please check setting.
solarwind
« Reply #4 on: December 03, 2008, 05:11:42 17:11 »
why not?
Setting? What do you mean? I checked everything I could. What do I have to do to get this to work?
« Last Edit: December 03, 2008, 05:14:21 17:14 by solarwind » Logged
solarwind
« Reply #5 on: December 15, 2008, 05:36:59 05:36 »
Still doesn't work...
mick
-Given: 2055
-Receive: 122
« Reply #6 on: December 29, 2008, 09:03:11 09:03 »
same problem with HI-Tech C8051 9.70 and Hi-Tide 2.13
info from user's manual:
"HI-TIDE is able to automatically detect and integrate installed HI-TECH
compilers that are compatible with HI-TIDE. The compiler used with HI-TIDE
is able to be selected when creating a project or working with a project."
  So I guess we have to wait for new versions of HI-TIDE
bunion
-Receive: 4122
« Reply #7 on: December 31, 2008, 04:33:27 16:33 »
Mike the "other" hitec 8051 compiler DOES WORK in the OLD hitide 2.13 ..latest hitide is 3.16
i saw ur other post and im currently tring to register that 8051 version for u ..should sort it soon...not patched but licensed Smiley
bunion
solarwind
« Reply #8 on: January 08, 2009, 11:48:23 23:48 »
http://forum.htsoft.com/all/showflat.php/Cat/0/Number/86152/an/0/page/0#Post86152
The latest beta adds support for the PIC32. Going to download and test now, I'll report back.
