April 05, 2025, 04:40:52 04:40
Author Topic: CCS PCWH 4.078  (Read 29193 times)
belinao
-Receive: 12
« on: November 20, 2008, 06:31:13 18:31 »
Hello everyone,
 I´ve found this CCS version, it is not the newest but it is newer than the others i found here.
enjoy
anonym.to/http://rapidshare.com/files/165716979/CCS_4.78.rar.html
ulderico
-Given: 157
-Receive: 819
« Reply #1 on: November 20, 2008, 07:41:35 19:41 »
Re-Upload please!
File not found
Tank you!
Wannabe
-Given: 228
-Receive: 285
« Reply #2 on: November 20, 2008, 08:55:01 20:55 »
It's simply one of rapidshare's latest idiotic limitations!
Please please use any other filehosting!
Here's a new mirror:
http://www.mediafire.com/?1ga0mn0muqt
« Last Edit: November 20, 2008, 09:54:17 21:54 by Wannabe » Logged
mayler
Roger that!
« Reply #3 on: November 20, 2008, 11:57:06 23:57 »
Belinao
Are you sure this is 4.078? I installed and in the about appears 4.074.
Edit :
I reinstalled and now appears 4.078... Only God knows why...
« Last Edit: November 21, 2008, 12:02:13 00:02 by mayler » Logged
Computer Engineer.
Digital IC Designer - Cadence certified.
FriskyFerret
-Given: 513
-Receive: 360
Put it in, take it out.
« Reply #4 on: November 21, 2008, 12:59:14 00:59 »
What's the "CCS_4.78_DLL.rar" file for? Are these crack files because the .CRG files do not fully authorize this version?
Contents:
pcd.dll
ccsicdU.dll
Ccsicd.dll
Pcb.dll
pcm.dll
Pch.dll
Ccswatch.dll
mayler
Roger that!
« Reply #5 on: November 21, 2008, 02:14:40 14:14 »
FriskyFerret
In the first install time, i thought that was not working because of missing cracked dlls, but these dlls are smaller than the originals (the files that the installer copy in the directory).
My procedure was :
Install (1st time)
Copy the dlls
Install (2nd time)
I dont know why the installer in first time asked for a reboot... I didnt do that, maybe the reason the first install didnt work.
I had the 4.074 before, cracked.
Now i have 4.078 except the PCWHD, v. 4.068...
Computer Engineer.
mick
-Given: 2103
-Receive: 122
« Reply #6 on: November 21, 2008, 03:45:49 15:45 »
also found this
http://rapidshare.com/files/165968362/PIC_4_78.rar
FriskyFerret
-Given: 513
-Receive: 360
« Reply #7 on: November 22, 2008, 12:39:22 00:39 »
mick's archive exactly matches belinao's.
yahoo
-Given: 56
-Receive: 111
« Reply #8 on: November 22, 2008, 01:10:01 01:10 »
I also don't understand what is the use of the DLT archive. After instalation without replacing the original dlts everithing seems to be OK. I was able to compile all of my big projects using the old license files.
FriskyFerret
-Given: 513
-Receive: 360
« Reply #9 on: November 22, 2008, 02:08:46 02:08 »
That was my question. In the past, the CCS compiler has been cracked with license files, not substitute DLL files. It seems odd that a version with a bunch of cracked DLL files would show up on the scene.
belinao, may we ask what your source was?
belinao
-Receive: 12
« Reply #10 on: November 24, 2008, 10:36:10 10:36 »
hello,
Sorry for taking so long to reply...
The source is a pic discussion group from Brazil... there they did not mention the reason of this dll, but as it was inside the archive I sent it here as well...
Everybody who has installed did not need to copy the DLLs ?
spasbyspas
-Given: 736
-Receive: 366
« Reply #11 on: November 24, 2008, 11:24:18 11:24 »
Hi,"belinao"! Yes man, not need Dll's. I installed over old ver.4.074 and work fine!
krumper88
-Given: 133
« Reply #12 on: November 26, 2008, 02:23:32 14:23 »
I deleted the dll files prior to running the install and mines running fine as well.
kiashee
-Given: 80
« Reply #13 on: December 13, 2008, 04:11:18 04:11 »
i installed this over a cracked v4.68. Its working fine.Smiley
i din't even have to apply crack or anything.
DarthPic
V.I.P
-Given: 728
-Receive: 75
« Reply #14 on: December 13, 2008, 08:44:29 08:44 »
Hi  Smiley
I do it like you Kiashee  Wink
Can you check the about page for the PCD version ?
Everything is going to 4.078 but PCD stay on the old version , no clue why  Grin
Cya.
Theory is when we know everything but nothing work ...
Practice is when everything work but no one know why Wink ...
mayler
Roger that!
« Reply #15 on: December 13, 2008, 07:28:52 19:28 »
Hi  Smiley
Cya.
Its because only the PCWH version is installed. The last PCWHD version here (in forum) is 4.068.
Computer Engineer.
kimhuynguyen
-Receive: 26
« Reply #16 on: December 14, 2008, 04:27:31 04:27 »
Belinao
Edit :
Copy file pcd.dll only
