November 23, 2024, 05:07:41 17:07
Author Topic: REQ - Loop current  (Read 3816 times)
niktesla
-Given: 166
-Receive: 280
« on: November 17, 2008, 08:40:18 20:40 »
I need test equipment that works with a stream of 4-24 MA, someone knows some very simple circuit that can be done with few components?
niktesla
dennis78
Online Online
-Given: 272
-Receive: 154
« Reply #1 on: November 17, 2008, 09:10:55 21:10 »
you can use simply integrated solution with AD694 or some classic circuit with opamps like:
http://photos1.blogger.com/blogger/879/242/1600/v-to-i.gif
or you want something circuit with one resistor...   Wink
FriskyFerret
-Given: 513
-Receive: 360
Put it in, take it out.
« Reply #2 on: November 17, 2008, 09:58:13 21:58 »
Two 9V batteries, a multimeter set to mA, a resistor and a pot will do the job. Choose the resistor to set the current at 25 mA. Add a pot configured as a variable resistor with enough resistance to limit current to 3 mA. To use the test circuit, put the multimeter in the current loop and adjust the pot to your desired current.
Don't forget about the current sensing resistor in the multimeter.
« Last Edit: November 17, 2008, 10:04:36 22:04 by FriskyFerret » Logged
