April 27, 2025, 08:39:45 20:39
Author Topic: Clock, hours, minutes, seconds  (Read 9973 times)
Leonardo
-Receive: 63
« on: November 11, 2008, 04:38:08 16:38 »
Hello friendly,
I want to do a clock with pic16f628 or some other pic that marks the hours, minutes and seconds. ¿Somebody of the forum has some example realized in picbasic pro?.
Thanks for its aid.
-Given: 405
-Receive: 545
« Reply #1 on: November 11, 2008, 05:21:35 17:21 »
Do your own searching,there are ton's of examples here and all over the internet if you just tried searching!
but here's a good one to start your lazy ass Wink
fernandodiaz
« Reply #2 on: November 12, 2008, 03:53:01 03:53 »
'here some sample clock timer0  proton plus   xtal 4mhz  output LCD   remplace   all  dims   Dim ticks   as     byte   for  var
' and some directives lcd remplace print  for lcdout $fe read manual pbp
'DECLARE WATCHDOG = off ' xtal 4mhz
      DEVICE = 16F877
       'device = 16f874a
        XTAL = 4
LCD_DTPIN = PORTb.4
LCD_RSPIN = PORTb.2
LCD_ENPIN = PORTb.3
LCD_INTERFACE = 4 ' 4-bit Interface
LCD_LINES = 2
LCD_TYPE = 0
SCL_PIN = PORTe.0
        SDA_PIN = PORTe.1
SERIAL_BAUD = 9600
RSOUT_PIN = PORTb.0
RSOUT_MODE = INVERT
RSOUT_PACE = 1
'   dim contador as dword
Dim MINUTO  as     byte    ' Define MINUTO variable
Dim SEGUNDO as     byte    ' Define SEGUNDO variable
Dim ticks   as     byte    ' Define pieces of seconds variable
Dim update  as     byte    ' Define variable to indicate update of LCD
Dim i       as     byte    ' Debounce loop variable
        Delayms 100        ' Wait for LCD to startup
                          ' Set initial time to 00:00:00
        MINUTO = 0
        SEGUNDO = 0
        ticks = 0
        update = 1      ' Force first display
        OPTION_REG = %1010111        ' Set TMR0 configuration and enable PORTB pullu
        INTCON = $A0            ' Enable TMR0 interrupts
            Cls
        On Interrupt Goto Tickint '_________________Interrupcion___________________________
'____________________________
mainloop:
    If update = 1 Then
           ' Clear screen
Print AT 1,1,    dec2 MINUTO, ":", dec2 SEGUNDO
     update = 0      ' Screen updated
    Endif
Goto mainloop    ' Do it all forever
 '______________________________
        Disable          ' Disable interrupts during interrupt handler
Tickint:
tmr0 = 12 ' .0625s * 16 = 1 seg   36 microseg de error por tick o 576 microseg x seg
  ticks = ticks + 1          ' Count pieces of seconds
        If ticks < 16 Then tiexit       ' 16 ticks per SEGUNDO (.0625 per tick)
        ticks = 0
        SEGUNDO = SEGUNDO + 1
        If SEGUNDO >= 60 Then
           SEGUNDO = 0
MINUTO = MINUTO + 1
If MINUTO >= 60 Then
   MINUTO = 0
    Endif
        Endif
        update = 1      ' Poner en lcd  update LCD
Tiexit: INTCON.2 = 0    ' Borrar bandera timer interrupt flag
        Resume
best regards
« Last Edit: November 15, 2008, 11:16:05 23:16 by Wizpic » Logged
Shinta
-Given: 20
« Reply #3 on: November 15, 2008, 11:11:59 23:11 »
Why you don't try the ds1307 ic commanded via I2C bus with 16f628. is too much easy an exactly.
Biggles
-Given: 15
-Receive: 24
« Reply #4 on: November 16, 2008, 08:57:37 20:57 »
Many clocks on Google search for PIC Basic Pro, but here is a nice one I have used myself:
3 Button adjustment of a DS1307 RTC
"The circuit uses a PIC16F84 and a standard 16*2 LCD.
.. tested the program on the following Pic chips, 16F84, 16F628(7), 18F1320(1220) and 18F452(252). "
http://anonym.to/?http://wiki.picbasic.org/index.php?n=ThreeButtonadjustmentofaDS1307RTC.RTC
Also easy to modify to SPI bus. I used it on a clock with good results using DS1305.
For clock only, a RTC is a little overkill. My application had a time display function when in standby, so I had to use a RTC. Very easy!
« Last Edit: November 16, 2008, 09:18:50 21:18 by Biggles » Logged
