November 24, 2024, 01:35:11 01:35
Author Topic: Mysterious ... at least for me! - PIC CCS  (Read 3910 times)
niktesla
-Given: 166
-Receive: 280
« on: November 07, 2008, 08:00:41 20:00 »
I need help to find out why the routine of interruption (# int_rda) does not work in this program.
If it is removed everything that does not depend on her work.
niktesla Smiley
j0k3r
-Given: 44
« Reply #1 on: November 08, 2008, 01:12:28 13:12 »
First: "set_tris_d(0b11111111); //somente o pino 2 da porta 'D' como entrada." (Estás a configurar todos como entradas.)
All pin´s configured for input´s, and not like you said "only pin2 input".
But your problem is the INT_TIMER0. Just disable it and your program run´s, OR add this lines to your code:
#int_timer0
void timer0()
//não precisas de ter aqui nada, ou como tens a intenção de o usar, apenas tens de indicar a INT do timer0.
niktesla
-Given: 166
-Receive: 280
« Reply #2 on: November 09, 2008, 12:17:00 12:17 »
Hi j0k3r,
There is a proverb in my country that says so: Living and learning ... and dying without knowing! Thank you Cheesy
niktesla
