November 24, 2024, 06:44:14 06:44
Author Topic: Need help...... i2c 1master + 2 slave (PIC)  (Read 8142 times)
pecpys
« on: October 28, 2008, 03:16:46 15:16 »
Could you please to help me.....
In simulation by use proteus. CCS v4.047 PIC18F45J10
I use Pic for master and another one is slave.
It can communication good.
but if I add RTC IC (DS1307) to bus. the communication is fail.
I see the slave PIC address = 0xA0) has interrupt every time. although master read RTC IC (address = 0xD0) the slave PIC has interrupt too. Why?
Anybody could you check this for me?
Proteus error or CCS error? Huh Huh
Thanks you very much
FriskyFerret
-Given: 513
-Receive: 360
Put it in, take it out.
« Reply #1 on: October 28, 2008, 03:35:46 15:35 »
I find it amusing that you didn't even consider a third reason for the problem was an error on your part.
pecpys
« Reply #2 on: October 28, 2008, 03:56:46 15:56 »
I'm sure the problem is not come from code.
because the problem is it has interrupt although the address is not it's address.
The master is use library 24512.c for reading.
The slave code is..
#use i2c(SLAVE, SDA=PIN_C4, SCL=PIN_C3, address=0xA0, FORCE_HW)
#INT_SSP
void ssp_interupt ()
BYTE state, data;
   state = i2c_isr_state();
   if(state < 0x80)                        //Master is sending data
      if(state == 0)                        //First received byte is high address
      else if(state == 1)                        //First received byte is high address
         while(!i2c_poll()) ;
         data =i2c_read();
          high_address = data;
      else if(state == 2)               //Second received byte is low address
         data =i2c_read();
         low_address = data;
      else
         data =i2c_read();
         if (high_address == 0)
            coils_status[low_address] = data;
            low_address++;
         else if(high_address == 1)
            inputs_status[low_address] = data;
            low_address++;
         else if(high_address == 2)
            hold_regs[low_address] = data;
            low_address++;
         else if(high_address == 3)
            input_regs[low_address] = data;
            low_address++;
   if(state >= 0x80)                     //Master is requesting data
      output_bit( PIN_C2,0);
         i2c_write(coils_status[low_address]);
         low_address++;
         i2c_write(inputs_status[low_address]);
         low_address++;
         i2c_write(hold_regs[low_address]);
         low_address++;
         i2c_write(input_regs[low_address]);
         low_address++;
      else
         i2c_write(0x00);
pecpys
« Reply #3 on: October 29, 2008, 08:52:26 08:52 »
OK, Today I test by use real hardware.
The error is in proteus.
i2c interrupt in pic has interupt every time (although it is not correct address)
future
-Given: 11
« Reply #4 on: October 31, 2008, 02:14:35 14:14 »
I've noticed the same thing, proteus is not right. You can make your code work though.
Make the pic interrupt on every i2c event, clear overruns if needed.
