November 24, 2024, 08:47:21 08:47
Author Topic: PWM RF control remote  (Read 4892 times)
machine
-Receive: 34
« on: October 17, 2008, 02:06:28 02:06 »
Hello guys, i try find pwm rf control remote circuit, but failed. Anybody know?
Thanks!
dennis78
-Given: 272
-Receive: 154
« Reply #1 on: November 14, 2008, 10:46:58 22:46 »
Can you explain what you want exactly?
Ikaros
-Given: 422
-Receive: 48
« Reply #2 on: December 02, 2008, 08:41:37 20:41 »
What do you want? Ready made project or you have a project not working?
PWM with PIC is quite easy. All you need is a resistor and a Capacitor to have clean DC output.
LazBoy
-Given: 78
-Receive: 25
« Reply #3 on: December 03, 2008, 06:57:22 06:57 »
@signalcom
How can we generate 60 kHz PWM with 16F876 or 16F877 @20 MHz Clock ?
This is possible ?
Ikaros
-Given: 422
-Receive: 48
« Reply #4 on: December 03, 2008, 09:29:28 09:29 »
For 78.12Khz you have to set Timr Prescaler  to 1, PR2 at 0x3F with mx resolution 8 bits. With 10 bits you will get max 19,53KHz only.
titi
-Given: 3807
-Receive: 834
« Reply #5 on: December 03, 2008, 05:53:42 17:53 »
This link can help you:
http://www.micro-examples.com/public/microex-navig/doc/097-pwm-calculator.html
To Have 60Khz with 20MHz,it give not the exact fréquency you want: (60240.96 Hz)
 * PWM registers configuration
 * Fosc = 20000000 Hz
 * Fpwm = 60240.96 Hz (Requested : 60000 Hz)
 * Duty Cycle = 50 %
 * Resolution is 8 bits
 * Prescaler is 1
 * Ensure that your PWM pin is configured as digital output
 * this source code is provided 'as is',
 * use it at your own risks
PR2 = 0b01010010 ;
T2CON = 0b00000100 ;
CCPR1L = 0b00101001 ;
CCP1CON = 0b00011100 ;
Best regards.
machine
-Receive: 34
« Reply #6 on: December 03, 2008, 07:53:11 19:53 »
Well, it would be a circuit that controlled a DC motor via RF using a PWM.Well, it would be a circuit that controlled a DC motor via RF using a PWM.
Ikaros
-Given: 422
-Receive: 48
« Reply #7 on: December 04, 2008, 08:38:25 08:38 »
Here is a little utility that helps alot in PIC calculations from Steve Monfete.
