April 04, 2025, 04:19:11 04:19
Author Topic: [REQ] 16*2 LCD datasheet....  (Read 7498 times)
MAXPAYNE
-Given: 502
-Receive: 368
It's a little funny......
« on: October 15, 2008, 06:18:59 18:18 »
Does anyone have this lcd datasheet......? Huh Huh Huh
Solomon LM2338SGR 16*2 lcd
It is a 14 pin lcd........
Thnks in advance
Biggles
-Given: 15
-Receive: 24
« Reply #1 on: November 17, 2008, 12:58:35 12:58 »
Have you tried to look up the datasheets for the display IC's?
MAXPAYNE
-Given: 502
-Receive: 368
« Reply #2 on: November 17, 2008, 03:17:09 15:17 »
yes
TomJackson69
-Receive: 63
« Reply #3 on: November 17, 2008, 06:55:12 18:55 »
Thnks in advance
Hi Maxpayne,
I tried to search for the LCD data sheet for your part number but no luck. What I think is that if your LCD has the HD44780 (or compatible) and has 14 or 16 pins than you can try to connect your LCD according to the most popular LCD; like Hantronix, CrystalFont and other.
As far as I concern, most LCD manufacturers follow the standard pin out so that they hope customer can use their LCD to replace the existing design. I have used Hantronix, Sony and Lumex with 16x2, 20x2 and 20x4 and found that they all have same pin out (with HD44780 driver).
Ignor pin 15 and 16 if your does not has back-light. Please precause if you have only one LCD. Go to Hantronix download the data sheet.
Good luck
Con Rong Chau Tien
MAXPAYNE
-Given: 502
-Receive: 368
« Reply #4 on: November 18, 2008, 04:02:38 16:02 »
Hello TomJackson69,
       I already tested the display as connected in standard pinout but the display didn't work...... i think it is not HD44780 compatible. it doesn't have anybacklight........
Biggles
-Given: 15
-Receive: 24
« Reply #5 on: November 18, 2008, 09:11:52 21:11 »
Post the part numbers of the chips on the display.  If you can locate a datasheet for a similar display chip in the family, you could get some driving clues.
Matrixx
-Given: 68
-Receive: 37
« Reply #6 on: November 18, 2008, 09:22:13 21:22 »
Have a closeup picture of back/top of the board... ?
MAXPAYNE
-Given: 502
-Receive: 368
« Reply #7 on: November 19, 2008, 03:36:35 03:36 »
This is a "COB" type lcd (2 COB) , so it doesn't have any part no. on it............
TomJackson69
-Receive: 63
« Reply #8 on: November 19, 2008, 08:55:11 20:55 »
Maxpayne,
Before you go any further, first of all, you must have your LCD routine works. Did you try your program on something else like Proteus? What compiler are you using? Do you have LCD driver work?
If it is work on the Proteus but not on you hardware than, there is timing problem. Try to increase delay for when you send command and data. I used longer delay for Command than dalay for data. For CMD try delay 8mS and for write data try delay 15uS. If its work, decrease the delay until the display display with missing char.
If you need LCD routines, I will post.
Tom
Con Rong Chau Tien
MAXPAYNE
-Given: 502
-Receive: 368
« Reply #9 on: November 22, 2008, 03:17:50 03:17 »
Maxpayne,
Tom
Thnks Tom for uor reply.
i tetsted another module and it is working. So i think i am not connecting the solomon lcd rightly.
please post the lcd routines...
MAX
-Given: 405
-Receive: 545
« Reply #10 on: November 22, 2008, 12:48:31 12:48 »
Tom I have a Lumex 16x2 here that doesn't follow the normal pin-out, pin 1 is power and pin 2 is ground and if I didn't read the datasheet it would have been ruined,so even name brand lcd's have some wierd pin-outs not just the cheaper ones.By the way I bought that one at Digi-Key(2 years ago) and was not expecting that weird pin-out so don't assume that just because it's a name-brand lcd your getting a normal lcd pin-out from them so that's why you should alway's try and find the datasheet if possible.
Max if you can't find it though just try it with the normal pin-out and if it blows it will be as useless as it is right now sitting there doing nothing
Hi Maxpayne,
Good luck
Biggles
-Given: 15
-Receive: 24
« Reply #11 on: November 22, 2008, 02:31:43 14:31 »
Have you put a contrast resistor on the solomon? Your display may be working, you just cant see the characters.
http://www.pacificdisplay.com/lcd_cont_adj.htm
Try pin 3 connected to the wiper of 10K pot from 5V to 0V.
TomJackson69
-Receive: 63
« Reply #12 on: November 22, 2008, 06:04:36 18:04 »
Maxpayne and Bbarney,
Sorry on my mistake. I did not clearly explain.
And Biggles is right, pin 3 (if it is right pin for contrast) connect to 10K wipper. I used 10K connected to +5V and 330 ohms to GND for contrast. Without contrast adjustment, you may not see the display.
Maxpayne, what compiler are you using? I will post the routine in MCC18 tonigh when I get home.
Tom
« Last Edit: November 22, 2008, 06:11:54 18:11 by TomJackson69 » Logged
Con Rong Chau Tien
TomJackson69
-Receive: 63
« Reply #13 on: November 23, 2008, 12:31:59 00:31 »
MAX
Hi Max,
Here is the LCD driver for MCC18:
Sorry, I can not attach the file, I will try on the Quick Reply.
Tom
Posted on: November 23, 2008, 01:17:15 01:17 - Automerged
Hi Max,
Now it is better, in this quick reply I see many options. Grin
CustomLCDdvr8bit.c        is .c file
CustomLCDdvr8bit.rar      is .h file
If you have a question, please post. Grin
Good luck,
Tom
Con Rong Chau Tien
MAXPAYNE
-Given: 502
-Receive: 368
« Reply #14 on: November 23, 2008, 02:12:29 14:12 »
Finally I got my lcd working !
According to bbarney I downloaded the datahseet for Lumex 16*2 and connected it and wow !!!!! it is working.....
I am attaching the dtst here if anyone need.......
Thnks to all of u for great support.......
SONSIVRI ROCKS!!!
-Given: 405
-Receive: 545
« Reply #15 on: November 23, 2008, 02:20:05 14:20 »
Good for you Max.
Sometimes you just got to take a chance that it's a normal pin-out otherwise it just sits on a desk never to work -- just like a blown lcd  Grin
