November 29, 2024, 10:50:52 22:50
Author Topic: How to build infrared detector...  (Read 4032 times)
chithanh04dt2
-Given: 97
« on: October 15, 2008, 04:22:06 16:22 »
Can you help me?
I want to use infrared LED as an electrical circuit can feel the presence of man in space 40 cm. Sorry because I do not speak English very well
Sorry for my English.
Regard !
ajak
-Given: 199
-Receive: 77
« Reply #1 on: October 16, 2008, 05:09:53 17:09 »
Sure, i can help you..
this is the answer to your question..
http://www.seattlerobotics.org/encoder/200112/richk.htm  Wink Cheesy Grin
ask question but also share your knowledge too.  Smiley Smiley Wink
sonsivri the best forum...
chithanh04dt2
-Given: 97
« Reply #2 on: October 22, 2008, 06:35:53 06:35 »
I have tried do but about how income and very short. How about ways to increase revenue in the infrared LED?
« Last Edit: October 22, 2008, 06:37:39 06:37 by chithanh04dt2 » Logged
Regard !
ajak
-Given: 199
-Receive: 77
« Reply #3 on: October 22, 2008, 09:26:35 21:26 »
if you like to know more about infrared proximity sensor, you could also read this:
this could help you and decide what you like to build.   Cheesy
http://www.ikalogic.com/ir_prox_sensors.php
http://www.ikalogic.com/ir_prox_sensors_40khz.php
sonsivri the best forum.........................  Wink
TomJackson69
-Receive: 63
« Reply #4 on: October 23, 2008, 04:53:14 04:53 »
Can you help me?
Hi Thanh,
Why don't you use photo sensor? it could be easier than use IR; since the distance you required is very close (only 40 Cm). Put the photo sensor (or RTS) in an enclosure and drill a hole for sensing. The size of the hole and the amplifier will allow you to adjust the sensitivity of the detector.
Search on the web for it. I am sure there are plenty of the circuits.
Go here: http://www.electrokits.com/photo/sensor
Go here for "Visible Light Photo-Detector Circuits - Basic Phototransistor Detector":
http://home.cogeco.ca/~rpaisley4/PhotoDetectors.html
Good luck,
Tom
Con Rong Chau Tien
Jehan
-Given: 51
« Reply #5 on: December 25, 2008, 05:44:28 05:44 »
one of my friend had made a security prip using a Laser pointer and a LDR, try if this can work for you, the laser pointer can give a very straight beam and the distance can be increased
oscareev
« Reply #6 on: July 14, 2009, 06:17:57 06:17 »
In this site information spanish infrared
http://www.futureworkss.com/tecnologicos/electronica/cursocad/barrerainfrarrojos.htm
cali - colombia
abcsantosh
-Given: 33
« Reply #7 on: July 14, 2009, 07:38:27 07:38 »
Hi, see below links for Infrared Motion Detectors. The site has good explanation and applications too.
http://www.glolab.com/
http://www.glolab.com/pirparts/pirparts.html
http://www.glolab.com/pirparts/infrared.html
Have a Good Day
