Please help me ! I can't use Timer 0 with Pic 16F877 in Flowcode.... - Sonsivri
May 14, 2026, 12:05:43 00:05
Author Topic: Please help me ! I can't use Timer 0 with Pic 16F877 in Flowcode....  (Read 6750 times)
chithanh04dt2
-Given: 97
« on: October 01, 2008, 09:30:15 09:30 »
Hello anyone Smiley
I'am Vietnammese and i only starter learn PIC Angry.  I have a problem with Pic 16f877. When i used Flowcode for PIC to programming LED flasher on RB port, i used timer0 interrupt. It seem very well with Flowcode simulation  Grin, but when i used Proteus and opened file PICDEM2+ with PIC16F877 (C:\Program Files\Labcenter Electronics\Proteus 7 Professional\SAMPLES\VSM MPLAB Viewer\Eval Boards\PICDEM2+ with PIC16F877), a problem happen. It is not true. Huh
My teacher have kit PICDEM2 Plus but i want test my code first with Proteus. Can you help me why differrent Flowode vs Proteus.
Here my files:
Thank in advance.
chithanh04dt2
Sorry for my English.
Regard !
Robi
-Given: 56
« Reply #1 on: October 01, 2008, 08:00:22 20:00 »
chithanh04dt2, the key instructions in your code are:
option_reg.T0CS=1;
option_reg.T0SE=1;
that both make Timer 0 incrementing on high-to-low transitions on T0CKI pin.
You must ensure that an external clock drives the pin RA4/T0CKI to get it working.
