April 13, 2026, 06:19:47 06:19
Author Topic: HOW TO USE HPWM3/4/5 IN PIC18F8722  (Read 6581 times)
siriwat1977
« on: September 30, 2008, 07:41:46 19:41 »
HOW TO USE HPWM3 / 4 / 5 ON PORTG.0  PORTG.3   PORTG.4
EX
duty_1          var byte
duty_2          var byte
duty_3          var byte
duty_4          var byte
duty_5          var byte
mot1        VAR  PORTC.2   'HPWM1
mot2        VAR  PORTC.1     'HPWM2
mot3        var  PORTG.0       'HPWM3
mot4        var  PORTG.3         'HPWM4
mot5        var  PORTG.4           'HPWM5
    adcon1 = 7
    TRISC = %00000000
    TRISG = %00000
    duty_1  = 255
    duty_2  = 255
    duty_3  = 255
    duty_4  = 255
    duty_5  = 255
    gosub drive0
gogo:
        GOSUB   forward150
        GoTo gogo
End
drive:
    HPWM 1,duty_1,800
    HPWM 2,duty_2,800
    HPWM 3,duty_3,800
    HPWM 4,duty_4,800
    HPWM 5,duty_5,800
    Return
drive0:
    HPWM 1,0,800
    HPWM 2,0,800
    HPWM 3,0,800
    HPWM 4,0,800
    HPWM 5,0,800
    Return
forward150:
High  mot1
High  mot2
High  mot3
High  mot4
High  mot5
    duty_1  = 100
    duty_2  = 100
    duty_3  = 100
    duty_4  = 100
    duty_5  = 100
GoSub drive
pause 100
Return
from ex
HPWM1 AND HPWM2 IS WORK
BUT NO SIGNAL OUT PORT G.0  G.3  G.4
THANK YOU  Smiley
-Receive: 4459
« Reply #1 on: January 11, 2009, 01:48:50 01:48 »
Where are you setting your control registers?
adcon1 is only 1 port of 3, to control for analog control
you need to read data sheet.
this is small part of setup needed. for one port.
1. Set the PWM period by writing to the PR2 (PR4) register.
2. Set the PWM duty cycle by writing to the CCPRxL register and CCPxCON<5:4> bits.
3. Make the CCPx pin an output by clearing the appropriate TRIS bit.
4. Set the TMR2 (TMR4) prescale value, then enable Timer2 (Timer4) by writing to T2CON
(T4CON).
5. Configure the CCPx module for PWM operation.
