November 24, 2024, 08:30:32 20:30
Author Topic: Dimension layer of PCB  (Read 3797 times)
Soter
-Given: 24
« on: September 24, 2008, 01:48:06 01:48 »
I sent my desing in Gerber274X format to the PCB house. But I forgot to put de dimension layer or border layer.
Please, can anyone tell me in what file put the dimension layer?: Huh
    * Top Component Layer (Top Copper)
    * Bottom Solder Layer (Bottom Copper)
    * Top Silk Screen Layer
    * Bottom Silk Screen Layer
    * Solder Stop Mask Layer (Top Solder Mask)
    * Solder Stop Mask Layer (Bottom Solder Mask)
    * Excellon Drill Data
Please help me.
mylogin
-Receive: 16
« Reply #1 on: September 24, 2008, 07:46:59 07:46 »
It is better to put the dimension and border layer to all the layers,  it is much easier for PCB factory and you to compare the layers when you print it out and overlap all the layers together,  the PCB factory will remove it when they do the board.
Silent_Thunder
-Given: 56
-Receive: 20
« Reply #2 on: September 24, 2008, 09:48:29 09:48 »
Hi Soter;
Dimension layer has no need for the manufactuerer, all what matter to them is the Keep Out Layer, which really spcify the outer dimension of your PCB, lets say that your pcb have iregular shape ?? what the dimension layer can tell at this case......
Best regards
