April 22, 2025, 05:32:01 17:32
Author Topic: what is maximum frequency  (Read 4773 times)
aamir
-Given: 37
-Receive: 229
« on: August 28, 2008, 11:21:47 11:21 »
What is maximum INTERRUPT  frequency AVR at 5mZ  CAN HANDLE.Ie what shuold be maximum pulse width that can be handleled by external INT0 pin of avr.
Codeman
-Given: 31
-Receive: 20
« Reply #1 on: August 28, 2008, 02:55:45 14:55 »
Well, that depends of a lot of things:
Which frequency you are using to clock the AVR?
What is the language you will use? Assembler ?, C ? Basic?
Who long is the code inside the interrupt?
hate
-Given: 156
-Receive: 355
« Reply #2 on: August 28, 2008, 06:41:15 18:41 »
5MHz=200ns instruction cycle on AVR family. If I remember correctly 2 cycles for jumping to the interrupt vector and another 2 cycles for jumping to the interrupt service routine makes 4 cycles. If you won't use any other interrupt and don't have any instructions inside the ISR then complete time for the interrupt to be executed make 6 cycles including the 2 return cycles. This makes an easy calculation of 5/6MHZ for the frequency of a single and empty interrupt. You can calculate what you need by adding the cycles your real ISR will use to that calculation!
Regards...
Regards...
Codeman
-Given: 31
-Receive: 20
« Reply #3 on: August 28, 2008, 08:37:31 20:37 »
If you google for "AVR frequency counter" you will see some examples. This circuits / software will give you an ideia of what you can get from AVR. Most of the software is written in assembler because of the speed.
