November 28, 2024, 05:50:04 05:50
Author Topic: Modify the atx power supply( -12V more than 0.8A)  (Read 4544 times)
edi14_10
« on: August 26, 2008, 06:23:27 18:23 »
Hi. I have a ATX power supply. i want to use the +5V, +12V, and -12V. usually the -12v is just 0.8A. I need more than this. maybe almost equal to the current of +12v(12A). Does anyone have any suggestion to modify the power supply so i can get this condition? thanks for the advise.
marty.markoh
-Given: 192
-Receive: 433
Everything must B explored!Remember what U see!
« Reply #1 on: August 26, 2008, 07:40:27 19:40 »
Friend-this http://www.webx.dk/oz2cpu/radios/psu-pc1.htm  maybe help?! Or one in attach? Wink
-Given: 834
-Receive: 4322
« Reply #2 on: August 27, 2008, 01:01:31 01:01 »
Depends on your skill and the use you want to put the power supply to.
one way is to use two ATX power supplys, you need to remove the earth from the pcb
so you wire them as one unit.
with the earth removed you wire this.
psu-1 Black wire as -12 volt
psu-1 Yellow as common  zero volts
psu-2 Black as common with yellow from psu-1
psu-2 Yellow wire +12 Volt
for +5 Volt use Red wire from psu-2
other wires for psu-2 are as known with ref to common
the wires from psu-1 can be metered to show voltage.
« Last Edit: August 27, 2008, 01:02:25 01:02 by pickit2 » Logged
neelandan
« Reply #3 on: September 14, 2008, 10:42:26 10:42 »
The waveform of the voltage at the rectifying diodes (of the computer power supply) is usually a square wave.  So if you can identify the two points where the +12 diodes connect you can connect two other diodes in reverse  and duplicate the filter arrangements to get your -12 V supply.
If the two diodes are in a single (double diode) package, you might need to use equivlently rated single diodes.
Deep inside the carcass of a dead (short) circuit.
