April 22, 2025, 09:51:22 09:51
Author Topic: How to simulate AVR counter in avrstudio  (Read 5640 times)
aamir
-Given: 37
-Receive: 229
« on: August 26, 2008, 06:05:49 06:05 »
I am using ATMEGA8515 now i want to simulate counter function in  it in avrstudio . If i toggle PORTB0.0 PIN IN AVR SIMULATOR NO change in counter register.How to simulate counter function.
sam_des
-Given: 130
-Receive: 151
« Reply #1 on: August 26, 2008, 07:43:38 19:43 »
Hi Aamir,
See the AVRStudio's help. It can't simulate all the modes of Timer/Counter modules.
Better check it with Proteus or VMLAB. See also that DDRB has been set correctly.
reagrds,
sam_des
« Last Edit: August 26, 2008, 07:46:48 19:46 by sam_des » Logged
Belgitaes
-Given: 19
« Reply #2 on: August 28, 2008, 01:15:49 13:15 »
Hope this one help you i little
; AT90S8515:toggle PORTB0.0 PIN IN AVR SIMULATOR
; Belgitaes
.include "8515def.inc"
; Definicion de constantes y variables
; Pila
  .equ          PILA                   =0x0FF
.DSEG
; MEMORIA RAM
    .ORG                (PILA+1)
;            Vectores de interrupcion
.CSEG
    .ORG     0x0000
    rjmp        RESET                        ; RESET
    .ORG 0x0007
rjmp OverFlow0 ;OverFlow Temp/Cont0
;                       RUTINA DE RESET
RESET:  cli
        ldi        r16,HIGH ( PILA )
out        SPH,r16
ldi        r16,LOW (PILA )
out        SPL,r16
;*******DESDE AQUÍ VUESTRO CODIGO*****
;Configuracion De Los Puertos
out ddrB,r16;DDRB has been set As Output
cbr r16,0x01; Configuro Patilla 0 Del Puerto B A 0
out portB,r16; Escribe 1111 1110
sei ;Autorizacion Interrupcion General
;TimsK:
;                                                    |***Cuando El Bit Esta A 1 En TOIE0
;|--7--|--6---|--5---|--4---|--3---|--2--|--1--|--0--|***Se Valida La Interupcion
;|-----|------|------|------|------|-----|-----|-----|*** Timer /Counter0
;|TOIE1|OCIE1A|OCIE1B|  -   |TICIE1|  -  |TOIE0|  -  |** El Bit TVO0 Se Modifica
;|-----|------|------|------|------|-----|-----|-----|** En El Registro TIFR
;   0     0      0     0       0      0     1     0
ldi r16,0x02
out TimsK,r16
;Contador Ascendente Incrementa Desde 0 Hasta 256
;Se Activa El Bit TOV0 De Tifr Cada Vez Que El Contador Pasa De FF A 00 ( Overflow)
             ;256 x 8 = 2048 microsegundos
ldi r16,0xA3 ;2048/100 = 20,48 X 8 = 163,84
             ;163 Decimal = A3 Hexadecimal
             ;256 Decimal = 100 Hexadecimal - A3 = 5D
             ;5D = 93 x 8 = 744 microsegundos
out TcnT0,r16
;TccR0:
;|--7--|--6--|--5--|--4--|--3--|--2--|--1--|--0--|** Selector Del Factor De
;|-----|-----|-----|-----|-----|-----|-----|-----|** Pré-Division Del Reloj
;| MSB |     |     |     |     |CS02 |CS01 |CS00 |** Define Prescaler
;|-----|-----|-----|-----|-----|-----|-----|-----|** Por Señal Externa Pin T0
;                              |  0  |  1  |  0  |** Reloj Systema /8 CLK I/O/8 (Desde El Pre-Escalador)
ldi r16,0x02
out TccR0,r16
;Hacer Un Programa Que Tendra Un Bucle Infinito
;Que Haga Lo Que Quiera ! No Se Me Occure Nada !
;Asi Que Configuro La Salida Por Hacer Algo
;Del Puerto Para Cuando Salga Del Bucle .
ldi r16,0x01
;1Âș Vuelta Bucle Infinito
;2Âș Vuelta Bucle Salta A Stop
SaltoEnVacio:
tst r16
breq stop
rjmp SaltoEnVacio
OverFlow0:
out PortB,r16 ;toggle PORTB0.0 PIN IN A 1
clr r16
out TcnT0,r16 ;Contador A 0
out TimsK,r16 ;Deshabilito Interrupcion
reti         ; Retorno de La Interrupcion
;****HASTA AQUÍ VUESTRO CODIGO********
STOP:        rjmp        STOP   ;FIN DEL PROGRAMA
