November 25, 2024, 05:34:43 17:34
Author Topic: Soft start for three phase motor  (Read 3512 times)
tienngoc
-Receive: 45
« on: August 08, 2008, 01:39:06 13:39 »
Dear friends.
I have a problem: I want to build a soft start circuit for three phase motor  < 5KW.
Does anyone  help me? Show me books or soft about "Soft start for three phase motor".
Thanks alot.
« Last Edit: August 08, 2008, 01:42:05 13:42 by tienngoc » Logged
Walkura
-Given: 56
-Receive: 82
« Reply #1 on: August 08, 2008, 07:24:41 19:24 »
Maybe its a crazy idea (the simple option)
The simple option is ,can't you do it like with big transformers .
Small (high powered) resistor in serie that you will bridge after the initial inrush .
Second option a bit less simple but a lot more sophisticated .
That option is called a ac-ac chopper .
www.stmicroelectronics.com/stonline/books/pdf/docs/12105.pdf
You can simplify this schema quite a bit
(dispose of the switcher) use conventional powersupply .
Use a opto-gatedriver for the highside .
Leaves a bunch of fast diodes ,igbt's .
Ofcourse you will have to make something up with zerocrosssing detection to make it run nice in 3 phase .
Those mcu's aint that expensive just use 1 for every faseand have it triggered by zerocrossing Smiley
Goodluck and be carefull
