November 24, 2024, 09:56:12 09:56
Author Topic: Why does this statement produce compiler error?  (Read 3745 times)
LithiumOverdosE
-Given: 383
-Receive: 587
« on: August 07, 2008, 07:11:33 19:11 »
I'm not sure why but this simple code snippet at the line where "char count;" is declared produce following error in CCS: "A numeric expression must appear here."
#define LCD_ENABLE_PIN PIN_D0
#define LCD_RS_PIN PIN_D1
#define LCD_RW_PIN PIN_D2
#define LCD_TYPE 2
#include <lcd.c>
void main()
   set_tris_b(0b00001111);
   lcd_init();
   lcd_putc("\fTest...\n");
   lcd_putc("Another one...");
   delay_ms(2000);
   lcd_putc("\f2 Seconds Later\n");
   lcd_putc("LED high");
   output_high(pin_b0);
   delay_ms(3000);
   lcd_putc("\fN3 Seconds Later\n");
   lcd_putc("LED low");
   char count;
       for (count = 0; count < 3; count++)
            output_b(0b00000000);
            delay_ms(500);
            output_b(0b11111111);
            delay_ms(500);
       lcd_putc("\f");
Any ideas? I mean it's just the most standard declaration one could think of so I'm a bit perplexed. Huh
« Last Edit: August 07, 2008, 07:12:29 19:12 by LithiumOverdosE » Logged
spasbyspas
-Given: 735
-Receive: 366
« Reply #1 on: August 07, 2008, 07:27:47 19:27 »
Ok,  Man! This "char count;", must be move to under "void main()" function line exemple:
void main()
   char count;
LithiumOverdosE
-Given: 383
-Receive: 587
« Reply #2 on: August 07, 2008, 07:38:54 19:38 »
@spasbyspas
Thx m8!  Smiley That helped. I wondered why is that so and I realized that C doesn't allow variable declaration except at the very beginning of the function body. C++ on the other hand allows for variable declarations at any point in the function.
I guess I'm so very used to C++ that I really ought to check out ANSI C standard more often.  Roll Eyes
spasbyspas
-Given: 735
-Receive: 366
« Reply #3 on: August 07, 2008, 07:41:51 19:41 »
Yes, yes in C++ is diffrent Wink!
Best regarts!
SpasBySpas
cluoiset
« Reply #4 on: August 07, 2008, 08:58:01 20:58 »
Hi!
I'm just wondering. Why do you have to put it in the main function?
Isn't it better to put it before the main?
Does the compiler produce a different code?
Cluoiset
LithiumOverdosE
-Given: 383
-Receive: 587
« Reply #5 on: August 09, 2008, 08:41:48 20:41 »
@cuoiset
You mean something like a global variable? I don't really understand your question.
orange
-Given: 702
-Receive: 204
« Reply #6 on: August 10, 2008, 09:45:02 09:45 »
I think you didn't initialize the value of count. Try
char count = 0;
LithiumOverdosE
-Given: 383
-Receive: 587
« Reply #7 on: August 10, 2008, 05:37:21 17:37 »
@orange
Thx for the reply but as I said ANSI C only allows for variables to be declared at the beginning of the function body while you can initialize variable at any further point in the function. C++ however allows for variable declaration at any point in the function body.
