November 25, 2024, 12:54:33 12:54
Author Topic: Notebook PSU replacement  (Read 3170 times)
free
-Given: 71
« on: August 02, 2008, 12:21:48 00:21 »
hi friends,
I had an old Compag notebook and the PSU was damage.It's very expensive to replace with compaq part.
Spec compag PSU : output 18.5v 3.5A.
On the other side I had an unused Acer PSU with spec : output 19v 3.4A.
What do you think if I replace it with Acer PSU ?
It is possible to make battery management circuit unproperly working and damage the battery?
- Soichiro Honda -
rmmrmm
-Receive: 24
« Reply #1 on: August 02, 2008, 03:56:45 15:56 »
You are lucky having a second PSU.
The voltage diference is minimal , just check the polarity and add a 3A silicon diode between the PSU and the Laptop , you will get a constant 0,6 to 0,7 Volt of dropout in the silicon .
-Given: 834
-Receive: 4322
« Reply #2 on: August 03, 2008, 03:08:34 15:08 »
I have two Sony Laptop power supply units both rated at 19v 3.42A same model no. for each unit.
one gives out 20v and the other 18.2v so I belive it's not that tight a control for the output voltage.
