jeniusj
-Given: 11
« on: July 28, 2008, 07:48:48 07:48 » |
I am currently working on the project related to robot vehicle in which I am trying to use optical mouse as position sensor.......for that purpose I have to interface the PS2 mouse using Atmega88..........I have successfully implement it (making the use of PS2 library available at www.avrfreaks.net by Jan Pieter de Ruiter )by the Grace of God....but when I am trying to send this data serially.......UART does not work......and also mouse do not initializes but the routine for PS2 interface and for UART works fine individually.............I have modified the librararies as per my requirement........... my code is as follows..........although the following code uses the polling based transmission of UART but i have also tried interrupt based transmission,but all in vain.............. All useful comments and material is being warm welcomed........... my code is as follows /************************************************************************************* Title: C include file for the PS/2 mouse library (ps2mouse.c) Author: Jan Pieter de Ruiter <[email protected]> Date: 13-Jun-2002 Software: AVR-GCC with AvrStudio Target: Any AVR device
DESCRIPTION Advanced routines for implementing the ps/2 protocol for a mouse. I think the function names speaks for themselve. They return 1 if the function succeeds, 0 if they fail. You can get the errorcode (RESEND or ERROR) with ps2_GetError() if a function fails. I found that some mice does not work with these functions, so use these functions at your own risk
#ifndef __PS2MOUSE_H_ #define __PS2MOUSE_H_ 1
#define STREAM 0 #define REMOTE 1
#define STANDARDMOUSE 0x00
#define ONECOUNT_MM 0 #define TWOCOUNT_MM 1 #define FOURCOUNT_MM 2 #define EIGHTCOUNT_MM 3
#define SCALING1_1 0 #define SCALING2_1 1
#define RESEND 0xFE #define ERROR 0xFC
int lasterror; int MouseID; int MouseMode; int oldMouseMode;
struct MouseData { int Xmovement; int Ymovement; };
struct MouseStatus { int mode; int reportenabled; int scaling; int resolution; int samplerate; };
int ps2_GetError(void); int ps2_Init(void); int ps2_Reset(void); int ps2_Resend(void); int ps2_SetDefault(void); int ps2_SetSampleRate(int rate); int ps2_GetID(void); int ps2_SetRemoteMode(void); int ps2_ReadData(struct MouseData *data); int ps2_SetStreamMode(void); int ps2_GetStatus(struct MouseStatus *status); int ps2_SetResolution(int resolution); int ps2_SetScaling(int scaling);
#endif /************************************************************************************* Title: C include file for the PS/2 library (ps2.c) Author: Jan Pieter de Ruiter <[email protected]> Date: 13-Jun-2002 Software: AVR-GCC with AvrStudio Target: Any AVR device
DESCRIPTION Basic routines for implementing the ps/2 protocol (for a mouse, keyboard etc.)
**************************************************************************************/ #ifndef __PS2_H_ #define __PS2_H_ 1
#include <avr/io.h>
#define _BV(bit) (1 << (bit)) #define INB(sfr) _SFR_BYTE(sfr) #define SBI(x,y) (x |= (1<<y)); /* set bit y in byte x */ #define CBI(x,y) (x &= (~(1<<y))); /* clear bit y in byte x */ #define BIT_IS_SET(sfr, bit) (INB(sfr) & _BV(bit)) #define BIT_IS_CEAR(sfr, bit) (!(INB(sfr) & _BV(bit))) #define LOOP_UNTIL_BIT_IS_SET(sfr, bit) do {asm volatile ("nop"::);} while (BIT_IS_CEAR(sfr, bit)) #define LOOP_UNTIL_BIT_IS_CLEAR(sfr, bit) do {asm volatile ("nop"::);} while (BIT_IS_SET(sfr, bit))
/* Select ports for the CLK and DATA lines here **************/ #define CLKPORT PORTC // port for CLK line #define DATAPORT PORTC // port for DATA line #define CLK 0 // pin on CLKPORT for CLK line #define DATA 1 // pin on DATAPORT for DATA line
#define CLKDDR DDRC #define CLKPIN PINC #define DATADDR DDRC #define DATAPIN PINC /*******************************************/
void Delay(long Microseconds); // Function for internal usage int Read_ps2data(void); // Receives a data byte from a device void Write_ps2data(int data); // Sends a data byte to a device
#endif /////////////////////////////////////////////////////////////////////////////// // // Project :PS2 Mouse Interface // Designers :Jibran Ahmed // // ///////////////////////////////////////////////////////////////////////////////
#include <avr/io.h> #include <avr/interrupt.h> #include <avr/iom88.h> #include <util/delay.h> #include <util/parity.h> #include <string.h> #include "ps2.h" #include "ps2mouse.h" #define ATMEGA_88
void UART0_Init(void); void Init(void);
int main(void) { int mouseinf; int deltax; int deltay; int posx = 0; int posy = 0;
Init(); // UART0_Init(); while(1) // Loop forever { // while(!(UCSR0A & 0x20 )); //wait for UDRE flag // UDR0 = 'a';//(unsigned char)(posx); mouseinf=Read_ps2data(); deltax=Read_ps2data(); deltay=Read_ps2data(); if(mouseinf&0x10)deltax-=0x100; // Add sign bit to deltax if(mouseinf&0x20)deltay-=0x100; // Add sign bit to deltay posx += deltax; // Absolute X position posy+=deltay; // Absolute Y position } }
void Delay(long microseconds) { while (microseconds) microseconds--; //Wait about ____ microseconds }
int Read_ps2data(void) { int d[8]; int i,Parity; int f = 1; int Data = 0; CBI (CLKDDR,CLK) ; //Make CLK input CBI (DATADDR,DATA); //Make DATA input CBI (CLKPORT,CLK); //Make CLK Open CBI (DATAPORT,DATA); //Make Data Open
LOOP_UNTIL_BIT_IS_CLEAR(CLKPIN,CLK); //Ignore StartBit LOOP_UNTIL_BIT_IS_SET(CLKPIN,CLK); //Ignore StartBit
LOOP_UNTIL_BIT_IS_CLEAR(CLKPIN,CLK); //Recieve First Data Bit if(BIT_IS_SET(DATAPIN,DATA)) d[0] = 1; else d[0] = 0; LOOP_UNTIL_BIT_IS_SET(CLKPIN,CLK);
LOOP_UNTIL_BIT_IS_CLEAR(CLKPIN,CLK); //Recieve 2nd Data Bit if(BIT_IS_SET(DATAPIN,DATA)) d[1] = 1; else d[1] = 0; LOOP_UNTIL_BIT_IS_SET(CLKPIN,CLK);
LOOP_UNTIL_BIT_IS_CLEAR(CLKPIN,CLK); if(BIT_IS_SET(DATAPIN,DATA)) d[2] = 1; else d[2] = 0; LOOP_UNTIL_BIT_IS_SET(CLKPIN,CLK);
LOOP_UNTIL_BIT_IS_CLEAR(CLKPIN,CLK); if(BIT_IS_SET(DATAPIN,DATA)) d[3] = 1; else d[3] = 0; LOOP_UNTIL_BIT_IS_SET(CLKPIN,CLK);
LOOP_UNTIL_BIT_IS_CLEAR(CLKPIN,CLK); if(BIT_IS_SET(DATAPIN,DATA)) d[4] = 1; else d[4] = 0; LOOP_UNTIL_BIT_IS_SET(CLKPIN,CLK);
LOOP_UNTIL_BIT_IS_CLEAR(CLKPIN,CLK); if(BIT_IS_SET(DATAPIN,DATA)) d[5] = 1; else d[5] = 0; LOOP_UNTIL_BIT_IS_SET(CLKPIN,CLK);
LOOP_UNTIL_BIT_IS_CLEAR(CLKPIN,CLK); if(BIT_IS_SET(DATAPIN,DATA)) d[6] = 1; else d[6] = 0; LOOP_UNTIL_BIT_IS_SET(CLKPIN,CLK);
LOOP_UNTIL_BIT_IS_CLEAR(CLKPIN,CLK); if(BIT_IS_SET(DATAPIN,DATA)) d[7] = 1; else d[7] = 0; LOOP_UNTIL_BIT_IS_SET(CLKPIN,CLK);
LOOP_UNTIL_BIT_IS_CLEAR(CLKPIN,CLK); if(BIT_IS_SET(DATAPIN,DATA)) Parity = 1; else Parity = 0; LOOP_UNTIL_BIT_IS_SET(CLKPIN,CLK);
LOOP_UNTIL_BIT_IS_CLEAR(CLKPIN,CLK); //Ignore Stop Bit LOOP_UNTIL_BIT_IS_SET(CLKPIN,CLK); //Ignore Stop Bit
for (i = 0; i <8 ; i++) //Convert to Decimal { Data += d[i]*f; f *= 2; }
if(((Parity==0)&&(parity_even_bit(Data)==0))||((Parity!=0)&&(parity_even_bit(Data)!=0))) return Data; // Return data if received data is OK else { Write_ps2data(0xFE); // Send the "ReSend" command return Read_ps2data(); // Receive data again } return 0; } void Write_ps2data(int data) { CBI(DATADDR,DATA); // Make DATA input CBI(DATAPORT,DATA); // Make DATA open SBI(CLKDDR,CLK); // Make CLK output CBI(CLKPORT,CLK); // Make CLK open CBI(CLKPORT,CLK); // Cancel the mouse (if transmitting) // Delay(25); SBI(DATADDR,DATA); // Make DATA output CBI(DATAPORT,DATA); // Generate startbit // Delay(25); CBI(CLKDDR,CLK); // Make CLK input CBI(CLKPORT,CLK); // Make CLK open LOOP_UNTIL_BIT_IS_CLEAR (CLKPIN,CLK); // Send first data bit if((data&0x01)==0) { CBI ( DATAPORT,DATA ); } else SBI(DATAPORT,DATA); LOOP_UNTIL_BIT_IS_SET(CLKPIN,CLK); LOOP_UNTIL_BIT_IS_CLEAR(CLKPIN,CLK); // Send Second data bit if((data&0x02)==0) { CBI (DATAPORT,DATA); } else SBI ( DATAPORT,DATA ); LOOP_UNTIL_BIT_IS_SET( CLKPIN,CLK ); LOOP_UNTIL_BIT_IS_CLEAR( CLKPIN,CLK ); // etc. if((data&0x04)==0){CBI(DATAPORT,DATA); } else SBI (DATAPORT,DATA ); LOOP_UNTIL_BIT_IS_SET(CLKPIN,CLK); LOOP_UNTIL_BIT_IS_CLEAR(CLKPIN,CLK); if((data&0x08)==0) { CBI ( DATAPORT,DATA ); } else SBI ( DATAPORT,DATA ); LOOP_UNTIL_BIT_IS_SET(CLKPIN,CLK); LOOP_UNTIL_BIT_IS_CLEAR(CLKPIN,CLK); if((data&0x10)==0){CBI(DATAPORT,DATA);} else SBI(DATAPORT,DATA); LOOP_UNTIL_BIT_IS_SET(CLKPIN,CLK); LOOP_UNTIL_BIT_IS_CLEAR(CLKPIN,CLK); if((data&0x20)==0){CBI(DATAPORT,DATA);} else SBI(DATAPORT,DATA); LOOP_UNTIL_BIT_IS_SET(CLKPIN,CLK); LOOP_UNTIL_BIT_IS_CLEAR(CLKPIN,CLK); if((data&0x40)==0){CBI(DATAPORT,DATA);} else SBI(DATAPORT,DATA); LOOP_UNTIL_BIT_IS_SET(CLKPIN,CLK); LOOP_UNTIL_BIT_IS_CLEAR(CLKPIN,CLK); if((data&0x80)==0){CBI(DATAPORT,DATA);} else SBI(DATAPORT,DATA); LOOP_UNTIL_BIT_IS_SET(CLKPIN,CLK); LOOP_UNTIL_BIT_IS_CLEAR(CLKPIN,CLK); // Send parity bit if(parity_even_bit(data)==0){CBI(DATAPORT,DATA);} else SBI(DATAPORT,DATA); LOOP_UNTIL_BIT_IS_SET(CLKPIN,CLK);
LOOP_UNTIL_BIT_IS_CLEAR(CLKPIN,CLK); // Send stop bit SBI(DATAPORT,DATA); LOOP_UNTIL_BIT_IS_SET(CLKPIN,CLK); CBI(DATADDR,DATA); CBI(DATAPORT,DATA); CBI(CLKDDR,CLK); CBI(CLKPORT,CLK); LOOP_UNTIL_BIT_IS_CLEAR(CLKPIN,CLK); // Ignore acknowledge bit LOOP_UNTIL_BIT_IS_SET(CLKPIN,CLK); }
void UART0_Init(void) { PRR = PRR & 0b11111101; //Enable USART0, Enable ADC SREG = 0x80; //Enabling All Interupts UCSR0B = 0x00; //disable while setting baud rate UCSR0A = 0x02; UCSR0C = 0x06; UBRR0L = 0x0C; //set baud rate lo 0x67 for 8MHz 0x0C for 1MHz UBRR0H = 0x00; //set baud rate hi UCSR0B = 0x18; }
void Init() { DDRB = 0xFF; //PORTB as output DDRC = 0xFF; //PORTC as output Write_ps2data(0xFF); //Reset mouse // wait for codes while( Read_ps2data() != 0xfa); //Acknowledge while( Read_ps2data() != 0xaa); //Self test passed while( Read_ps2data() != 0x00); //Mouse ID
Write_ps2data(0xF4); // enable data reporting while( Read_ps2data() != 0xfa); }
/* ISR ( USART_TX_vect ) { //USART Transmission complete routine }
ISR ( USART_RX_vect ) {
ISR ( USART_UDRE_vect ) {
