April 22, 2025, 05:35:17 17:35
Author Topic: any one has this assembler A51 for 8051 ..?  (Read 6987 times)
Ronydc
« on: July 11, 2008, 08:17:28 20:17 »
dear friends,
any one using this assembeler for 8051 from the following firm .?
MicroKit
6910 Patterson SE
Caledonia, MI 49316
(616) 791-9333
if any one using the A51 from this companey .. please share it.
THANKS IN ADVANCE.
-- RONY.
pomidor
-Given: 36
-Receive: 90
« Reply #1 on: July 12, 2008, 07:59:08 07:59 »
Hi!
Google found
http://www.ai.uga.edu/ftplib/microcontrollers/8051/bas051.doc.txt
 D.   The assembly language output from BAS051 is based on the
          UNIX System V* assembler syntx.  The product, A51, by
          PseudoCode is an excellent assembler, reasonably priced,
          and can accept BAS051 .ASM files without modification.
          A51 is availiable from MicroKit, their address is:
                MicroKit
                6910 Patterson SE
                Caledonia, MI  49316
                (616) 791-9333
PseudoSam 8051 Cross Assembler, V1.4.09
http://www.sixca.com/tool/index.html
http://www.programmersheaven.com/download/3727/download.aspx
pomidor
-Given: 36
-Receive: 90
« Reply #2 on: July 12, 2008, 08:55:49 08:55 »
BTW, Keil has A51 Macro Assembler as part of 51 development tool
http://www.keil.com/c51/a51.asp
beque
-Given: 51
-Receive: 149
« Reply #3 on: July 30, 2008, 05:09:18 17:09 »
Hi Rony
If you work in Windows choose this
http://www.systronix.com/RAD51/RAD51.htm
RAD51 is an acronym for Rapid Application Development for 8051s.
RAD51 is an Integrated Development Environment (IDE) with a comfortable text editor, and an 8051 cross-assembler. It's a true 32-bit Windows application and requires Windows 9X or NT. Rather than tell you more here, you can check the data sheet or just download the whole program. It's free!
RAD51 takes a 'project' view of your code and retains basic information in a PRJ file. Shared code such as I/O routines can be kept in a 'parent' folder. Individual projects are stored in 'child' folders which can #include the shared code. We include several samples which illustrate this.
A $299 value (this lets you know it's worth a lot and not some cheap give-away), RAD51 is FREE!
embromation
-Given: 50
-Receive: 478
« Reply #4 on: July 30, 2008, 05:22:34 17:22 »
I use: Raisonance Ride
http://www.raisonance.com/products/info/RIDE.php
Compilers: Cool
MetaLink ASM51 v1.2k Cheesy
http://rapidshare.com/files/133609867/MetaLink_ASM51_v1.2k.zip
asem51 v1.3 Wink
http://rapidshare.com/files/133610518/asem51_v1.3.zip
Share your knowledge!
Joe_jj
« Reply #5 on: July 31, 2008, 07:13:03 19:13 »
MIDE-51: M-IDE Studio is good for me
http://www.opcube.com/software/midepack0258i.exe
