April 29, 2025, 04:12:16 04:12
Author Topic: 8051 core -- lets find out this configuration..  (Read 4745 times)
Ronydc
« on: July 11, 2008, 08:15:27 20:15 »
dear friends,
i m searching any 8051 compitible IC tht has following specifications
1> probable manufacturers --> Atmel , philips.
2> ISP Capability ---> must
3> has 5 i/o ports ( means around 40 i/o lines)
5> 12 machine cycle operation as conventional 8051 is having. --> must.
6> on chip EEPROM. FLASH MEMORY.
7> for ISP, windows based software available
all other extra.. -- no problem .
Can some one provide me the information about just the IC number having above configuration please....
thanks in advance...
RONY
quakeman
« Reply #1 on: July 13, 2008, 11:44:02 11:44 »
Atmel and NXP (philips) has good parametric search pages fpr the purpose of searching the right controller. So i would suggest you try this to find a controller with your needs. Smiley
30f4011
-Given: 764
-Receive: 96
« Reply #2 on: July 13, 2008, 01:34:58 13:34 »
dear friends,
RONY
AT89s8252-------->8051 core (ATMEL)
                            256-bytes of ram
                            8kb of Flash memory (AT89s8253-->12K falsh)
                            2kb of eeprom
                            3-timers,32 i/o
                            12 machine cycle
                            SPI
                            2 DPTR
                            ISP
                            free ISP software available
« Last Edit: July 13, 2008, 01:39:29 13:39 by 30f4011 » Logged
pak
« Reply #3 on: July 13, 2008, 03:09:52 15:09 »
before you try on lpc seris of philips, I suggest you should visit this site
 http://forum.flashmagictool.com/index.php?board=4.0
regarding about ISP
pak
