January 10, 2025, 11:00:57 23:00
Author Topic: how to connect external RAM to avr ?  (Read 15006 times)
omidsht
-Given: 60
-Receive: 16
« on: June 30, 2008, 05:50:03 05:50 »
hi , i have 2 questions :
1-how to connect external RAM to AVR ?
2-how to connect external FLASH to AVR /
thanks
omid
telyadi
« Reply #1 on: June 30, 2008, 10:31:18 10:31 »
read AVR datasheets around page 28: mega64, mega128, mega 8515.
pak
« Reply #2 on: June 30, 2008, 12:57:36 12:57 »
have a search with avr forum, here is some link for you to save time
http://www.avrfreaks.net/index.php?name=PNphpBB2&file=viewtopic&t=65026&highlight=external+ram
Matrixx
-Given: 68
-Receive: 37
« Reply #3 on: June 30, 2008, 01:13:52 13:13 »
I have try this setup some time ago. Works fine for 8535.
http://avrhelp.mcselec.com/index.html?adding_xram.htm
cluoiset
« Reply #4 on: June 30, 2008, 03:12:28 15:12 »
Hi!What kind of Ram do you want to use?
You can easily connect an eprom through i2c.
sacoroxo
-Given: 34
-Receive: 26
« Reply #5 on: July 01, 2008, 04:34:35 16:34 »
If you are talking about STATIC RAM --> http://avrhelp.mcselec.com/index.html?adding_xram.htm
and
If you are talking about COMPACT FLASH --> http://avrhelp.mcselec.com/index.html?compact_flashcard_driver.htm
[]´s
Codeman
-Given: 31
-Receive: 20
« Reply #6 on: September 05, 2008, 09:10:40 21:10 »
Be carefull. Not all the AVR's support XRAM. 8535 does. Mega64 and 128 also do. Mega32 for instance does not support XRAM.
« Last Edit: September 05, 2008, 09:13:04 21:13 by Codeman » Logged
