November 23, 2024, 09:04:53 21:04
Author Topic: CCS PCWH 4.074  (Read 17853 times)
mee48025
-Receive: 38
« on: June 21, 2008, 05:05:13 17:05 »
Hi All
I have uploaded ccs pcwh 4.074   at under link
http://rapidshare.com/files/124042065/PCWH_v4.074.rar.html
« Last Edit: July 06, 2008, 07:52:40 07:52 by metal » Logged
The Puma
-Given: 75
-Receive: 75
« Reply #1 on: June 22, 2008, 10:42:58 10:42 »
Did you can help us with the PCWHD compiler (4.074)?
mee48025
-Receive: 38
« Reply #2 on: June 22, 2008, 02:18:45 14:18 »
I only have pcwhd 4.068. do you want it?
xp338
-Given: 249
-Receive: 47
« Reply #3 on: June 22, 2008, 03:19:54 15:19 »
I install it over the old version(4.057) and the "old crg files" are working fine with 4.074.
I did compliered some project and it work...
The Puma
-Given: 75
-Receive: 75
« Reply #4 on: June 27, 2008, 06:30:47 18:30 »
Thanks, but this version did i own already
xzb
-Given: 16
« Reply #5 on: June 30, 2008, 02:06:42 02:06 »
why ccs pcwh 4.074 now not support this use?
  #define Nop() #asm nop #endasm
mayler
Roger that!
« Reply #6 on: July 04, 2008, 02:36:12 02:36 »
Here i compiled and worked... A solution for your problem can be delay_cicles(1); , who will generate a NOP in assembly code.
Computer Engineer.
petarp
-Receive: 51
« Reply #7 on: July 04, 2008, 09:08:33 09:08 »
hi, mayler. You mean delay_cycles(1);
papai
« Reply #8 on: July 05, 2008, 04:41:35 04:41 »
Hi All
I am facing the problems with th registry files. After I have installed the software ,it says that .CRG or .REG files not found. Pls suggest the remedy
« Last Edit: July 06, 2008, 07:52:13 07:52 by metal » Logged
cjeffries1
-Given: 252
-Receive: 176
« Reply #9 on: July 28, 2008, 05:51:54 17:51 »
Did you do an upgrade or a clean install of this version? If you had a previous version you may be better to uninstall everything with a professional uninstaller, clean the registry and start again
wnmaximino
-Given: 47
-Receive: 202
Homer
« Reply #10 on: September 04, 2008, 08:02:30 20:02 »
DonĀ“t working in windows vista!
CRG files error.
beque
-Given: 51
-Receive: 149
« Reply #11 on: September 04, 2008, 09:21:36 21:21 »
Attention Folks:
For working in Windows Vista dont install in default folder,
change to C:\PICC and join the files register to this folder.
wnmaximino
-Given: 47
-Receive: 202
Homer
« Reply #12 on: September 16, 2008, 09:07:09 21:07 »
DonĀ“t working in windows vista ultimate (C:\PICC)
CRG files error
Attention Folks:
The Puma
-Given: 75
-Receive: 75
« Reply #13 on: October 04, 2008, 12:38:29 12:38 »
Has someone an update to the latest 4.080 version?
If someone has 4.079 it also ok
« Last Edit: October 05, 2008, 09:25:47 09:25 by The Puma » Logged
spasbyspas
-Given: 735
-Receive: 366
« Reply #14 on: October 04, 2008, 05:04:28 17:04 »
Have a problem with new ver.4.080
http://www.ccsinfo.com/forum/viewtopic.php?t=36212
we will waiting for a next version!(If some one have v4.079 or 4.078 pleace give me Wink )
The Puma
-Given: 75
-Receive: 75
« Reply #15 on: October 09, 2008, 11:28:33 11:28 »
@spasbyspas ,
There is already an updated version 4.081
Maybe this fix the problems.
Please upload
preatorian
-Given: 16
« Reply #16 on: November 15, 2008, 04:20:33 16:20 »
Hi all,
current version is 4.082, can anyone upload it?
