November 27, 2024, 09:38:04 21:38
Author Topic: Vectric Cut2d  (Read 18330 times)
Nele
« on: June 08, 2008, 10:56:25 22:56 »
Anyone knows where i can find license code for Vectric Cut2d software?
Thanks.
-Given: 834
-Receive: 4322
« Reply #1 on: June 09, 2008, 12:45:13 00:45 »
If it was me asking - I would post a link to soft - then someone may have or try to crack.
offer a challenge, someone may run with it.
noo
« Reply #2 on: June 09, 2008, 11:27:46 11:27 »
Here is link http://www.vectric.com/WebSite/Vectric/cut2D/c2d_index.htm
« Reply #3 on: April 23, 2011, 05:50:21 17:50 »
Cut2D is designed to help Hobby CNC machine users convert CAD DXF and graphics designs into GCode / CNC Toolpaths for machining parts and components. Automatic cutter diameter compensation, machines designs precisely to size without having to worry about manually offsetting geometry for the cutter being used.
Automatically converts CAD drawings and Graphic designs to GCode / CNC Toolpaths.
Opens most industry standard 2D vector drawing formats DXF, EPS, AI & PDF file formats.
Pocket Machining with either raster or offset machining patterns, plus the option to ramp the cutter into the material.
Profile Machining-running the cutter around the outside, inside or on the selected geometry, with the option to ramp the cutter into the material.
Automatic cutter diameter compensation for toolpaths ensures parts are cut to the required size. Simply select the shapes and Cut2D compensates for the cutter diameter and shape.
Interactive Tab / Bridge placement to ensure parts are securely held in place when cutting from sheet material.
Automatic calculation for Outside and Inside cutting when multiple shapes are selected.
more info - http://www.vectric.com/WebSite/Vectric/cut2D/c2d_index.htm
15MB
http://www.fileserve.com/file/naTddq3
http://www.filesonic.com/file/819154604
