November 24, 2024, 10:34:37 10:34
Author Topic: help using pbp pro and SRF05 sensor  (Read 5991 times)
spurs21
-Given: 35
-Receive: 50
« on: June 03, 2008, 03:51:40 03:51 »
Hi friends, i have bought a SRF05 sensor and today has arrived to me Cheesy. I'm trying to test it with an 16x4 LCD but it does not works like i want, maybe im wrong in my code, i know that is very simple but i don't know why it does not works.
the info about this senor is here: http://www.msebilbao.com/notas/downloads/Medidor%20Ultrasonico%20SRF05.pdf
and this is my code:
Echo VAR Portb.2
Trigger var Portb.4
Ancho var word
Dist_cm var word
trigger = 0
main:
trigger = 0
pulsout trigger,1
pulsin echo,1,ancho
dist_cm = (ancho/29)
LCDOUT $FE, 1
LCDOUT "CM =", DEC DIST_CM
goto main
end
-Given: 834
-Receive: 4321
« Reply #1 on: June 03, 2008, 12:01:12 12:01 »
English data sheet http://ltc.cit.cornell.edu/courses/ee476/FinalProjects/s2008/cl457_yft2/cl457_yft2/datasheets/SRF05.pdf
looking at your code I would say your pulse out is too short 1us or 2us, it needs min 10us. echo pluse is returned in upto 25us if target is found and 30us if no target found.
SRF05 PIN 15                   ' use any pin for both trigger and echo
Range VAR Word               ' define the 16 bit range variable
SRF05 = 0                        ' start with pin low
PULSOUT SRF05, 5             ' issue [color=red]10uS[/color] trigger pulse (5 x 2uS)
PULSIN SRF05, 1, Range      ' measure echo time
Range = Range/29              ' convert to cm (divide by 74 for inches)
[/pre]
spurs21
-Given: 35
-Receive: 50
« Reply #2 on: June 03, 2008, 11:46:50 23:46 »
hi thanks for your answer man, i have fixed it  Grin, i was using a 4MHz crystal now i'm using a 20Mhz crystal and like u say the pulse with was very short, now its working ok thanks and regards  Smiley
