November 27, 2024, 03:48:28 15:48
Author Topic: Windows Based EPROM Programmer  (Read 4981 times)
zokij
-Given: 269
-Receive: 679
Nice time :)
« on: May 29, 2008, 05:05:53 05:05 »
The programmer has one ZIF (zero insertion force) socket for the EPROM to be programmed or read. This is a 32-pin socket which can be configured by the software to suit devices in 28-pin or 32-pin DIL packages, with capacities from 64Kb (kilobits) to 2Mb (megabits).
It can also be used to work with older 32Kb devices in 24-pin DIL packages and devices in 32-pin PLCC (plastic leadless chip carrier) packages with capacities from 64Kb to 2Mb. This is done with small matching socket adaptors which fit into the ZIF socket
link:
http://rapidshare.com/files/118480399/021.rar dead link
pass: sonsivri
new link:
Filename:     021.rar
Date:    2008-09-05 13:48:34
4 mirrors links:
http://rapidshare.com/files/142764805/021.rar.html
http://sharedzilla.com/en/get?id=192130
http://w13.easy-share.com/1701461999.html
http://www.filefactory.com/file/ada53f/n/021_rar
pass:sonsivri
« Last Edit: September 05, 2008, 09:31:41 09:31 by zokij » Logged
astroman132003
« Reply #1 on: May 29, 2008, 11:04:45 23:04 »
 Hello
 From what i saw this is only part2 of the project.
 Where is part 1?
mbandala
-Given: 130
-Receive: 305
« Reply #2 on: May 30, 2008, 12:23:39 00:23 »
Shouldn't this be in the newly created schematic section?
zokij
-Given: 269
-Receive: 679
Nice time :)
« Reply #3 on: May 30, 2008, 01:09:53 01:09 »
 Hello
 Where is part 1?
well you try "saw" again - when you unpack archive in main folder you can see part I and part II is in sub folder part II
I will prepare for you one PDF for complete project easy to use ...
Posted on: May 30, 2008, 02:07:09 02:07 - Automerged
No this is complete project and that mean for this section , I was make mistake and send few project at schematic section...
brijbhoomi
« Reply #4 on: August 12, 2008, 05:59:58 17:59 »
http://rapidshare.com/files/118480399/021.rar is not working
 error " The file could not be found. Please check the download link "
zokij
-Given: 269
-Receive: 679
Nice time :)
« Reply #5 on: September 05, 2008, 09:21:42 09:21 »
digg new link for you:
Filename:     021.rar
4 mirrors links:
pass:sonsivri
nice time Wink
« Last Edit: September 05, 2008, 09:29:27 09:29 by zokij » Logged
