November 25, 2024, 09:47:03 09:47
Author Topic: MCP23s08 help ?  (Read 5342 times)
dikris
-Given: 301
-Receive: 69
« on: May 18, 2006, 09:49:04 09:49 »
Hi all,
I have CCS project with PIC18f452 and 8 mcp23s08.I want to make  4 of them inputs with pull-up and another 4 - Outputs.I use hardware addressing pin(A0,A1) . Inputs and otputs have separately CS.
Can you advice me how to init those chips.When I send command to outputs all 4 chips recive same information.Any driver idea.
I wrote this driver:
void init_SPI()
output_low(SPI_CLK);
 delay_us(50);
output_low(SPI_DI);
output_high(OUTPUTS_CS);
output_high(INPUTS_CS);
   delay_us(50);
void mcp32s08_SendByte(BYTE data)
   BYTE i;
 delay_us(2);
  for(i=0; i<8; ++i)  //SEND DATA
   if(bit_test(data, 7))
   output_high(SPI_DI);
  else
   output_low(SPI_DI);
     // data=data>>1;
      delay_us(60);
      output_high(SPI_CLK);
      delay_us(40);
    data <<= 1;
void mcp32s08_write(BYTE address,BYTE reg,BYTE value,BYTE io)
  output_low(SPI_DI);
if(io==0)                 //outputs
output_low(OUTPUTS_CS);
else                        //inputs
output_low(INPUTS_CS);
 mcp32s08_SendByte(address);  //SEND OP CODE (ADDRESS)
 mcp32s08_SendByte(reg); //SEND REGISTER
 mcp32s08_SendByte(value);  //SEND VALUE
 init_SPI();
void mcp32s08_SetPulUp(BYTE address)
 address=address<<1;
 address=0x40+address;
mcp32s08_write(address,MCP23s08_GPPU,0xFF,1);
void mcp32s08_SetIOCON(BYTE address,BYTE dir)
 address=address<<1;
mcp32s08_write(address,MCP23s08_IOCON,0x04,dir);
void mcp32s08_Out(BYTE address,BYTE value)
 address=address<<1;
mcp32s08_write(address,MCP23s08_GPIO,value,0);
void mcp32s08_init(BYTE address,BYTE dir)
BYTE value;
 address=address<<1;
if(dir==1)
 value=0xFF;
else
 value=0x00;
mcp32s08_write(address,MCP23s08_IODIR,value,dir);
And the code of init is:
 for(i=0; i<4; ++i)  //INPUTS
mcp32s08_SetIOCON(i,1);
mcp32s08_SetPulUp(i);  //Pull Up - Internal
mcp32s08_init(i,1);
  for(i=0; i<4; ++i)  //OUTS
  mcp32s08_SetIOCON(i,0);
  mcp32s08_init(i,0);
  mcp32s08_Out(i,0x00);   //All Outs '0'
  mcp32s08_Out(0,0x01); //Here is the problem
After this bit 0 of all outs is 1, not 1 on first chip only.
Sorry of my English.
-Given: 405
-Receive: 545
« Reply #1 on: May 18, 2006, 11:17:46 11:17 »
maybe this will help
dikris
-Given: 301
-Receive: 69
« Reply #2 on: May 18, 2006, 11:58:05 11:58 »
The book describe I2C. MCP23s08 -> SPI, MCP23008 -> I2C.
robban
-Given: 34
-Receive: 38
Warrior
« Reply #3 on: May 18, 2006, 03:23:57 15:23 »
I can't find any significant error in Yr. code, but if I were You I should fiddle a little bit with the delay routines(timining can be critical when talking to external modules). I assume You have connected the hardware and pullup resistors OK.
Good Luck!:)
Code Warrior
robban
-Given: 34
-Receive: 38
Warrior
« Reply #4 on: May 18, 2006, 03:29:55 15:29 »
The rest of the code constitute "dir" as "BYTE dir". By the way, when You send us code, don't be sparse with comments and line numbers.
Code Warrior
dikris
-Given: 301
-Receive: 69
« Reply #5 on: May 18, 2006, 04:46:09 16:46 »
Thanks a lot.
void mcp32s08_SetIOCON(BYTE address,BYTE dir) //dir mean INPUTS-1 and OUTPUT - 0
address=address<<1;
//mcp32s08_write(address,MCP23s08_IOCON,0x04,dir); //WRONG VALUE - 0x04
 // HAEN(hardware address enable) is bit 3  ->  0x08 from IOCON Register
mcp32s08_write(address,MCP23s08_IOCON,0x08,dir); //CORRECT VALUE
dikris
-Given: 301
-Receive: 69
« Reply #6 on: May 18, 2006, 05:17:59 17:17 »
All registers from one of the MCP23s08(inputs) via RS232
IODIR=FF
IPOL=00
GPINTEN=00
DEFVAL=00
INTCON=00
IOCON=08
GPPU=00
INTF=00
INTCAP=00
GPIO=FF
OLAT=00
-Given: 405
-Receive: 545
« Reply #7 on: May 18, 2006, 10:28:20 22:28 »
sorry about that i just woke up when i read your post
robban
-Given: 34
-Receive: 38
Warrior
« Reply #8 on: May 19, 2006, 09:17:58 21:17 »
Hi Dikris!
Glad You made it...
Code Warrior
