November 24, 2024, 04:55:10 04:55
Author Topic: MCP23017 and Proton Basic  (Read 5880 times)
mmemory
« on: May 17, 2008, 08:27:20 08:27 »
Does Anybody use MCP23017 port expander with proton basic?
Posted on: May 16, 2008, 12:22:54 12:22 - Automerged
I think nobody used MCP23017 ?
This IC is 16 port bidirectional IO port expander.
Controls with SDA and SCL type bus.
I'm trying to use it but some functions does'nt work .
-Given: 834
-Receive: 4321
« Reply #1 on: May 17, 2008, 11:20:28 11:20 »
not suprised you got no take up on this
1:
that a question
2:
Statement and it must work or microchip would not sell them.
you do not say what funtions you can't get to work, again if they are in the data sheet, they sould work. Tongue
the MCP23017 we have used then in my place of work, but I'm off on sick leave, so can't look project up.
I don't remember any problem using them, with 16F690 and the 18F2550.
mmemory
« Reply #2 on: May 21, 2008, 12:36:27 00:36 »
Thanks pickit2
It works succesfully,
The problem was in proteus.
I tried to work with simulate program at the first time.
proteus gives fault sometimes. for example when write initialize line portA before portB gives an error,
when you remove pullup rezistors register line it works.
Finally it works on hardware.
I used 16F628
If I can find sample program it would be easier.
