November 24, 2024, 12:35:36 00:35
Author Topic: Question: PICBasic Pro how to receive more than 2 byte of data from PC  (Read 4555 times)
rod27cn
 Warned
-Given: 43
-Receive: 36
« on: May 11, 2008, 05:59:24 17:59 »
Hello, Can somebody help me on how to received more than 2 bytes of data from PC using PICBasic Pro. I am using PIC16F876A.
Please advise some idea or examples.
Thanks! Smiley
Posted on: May 11, 2008, 06:57:52 18:57 - Automerged
I am using RS232 communication by the way, I forgot to mention it.
strat
-Given: 11
« Reply #1 on: May 11, 2008, 08:19:09 20:19 »
You can use arrays. But the program worked on the PC must send data to Pic by byte variable.
maddoc
-Given: 49
-Receive: 14
« Reply #2 on: May 12, 2008, 08:47:22 08:47 »
I use a loop in the main program to receive nonstop data.
It usually can process around 19200bps of info with those CASE statements full of code.
I use to receive data also in the CASE statements, because some commands need 1 to 50 bytes of data.
MAIN:
C = HRSIN
IF C <> $FF THEN
;do something if it is not a start command character ( $FF )
ELSE
CMND = HRSIN
SELECT CMND
CASE X
             do something
CASE X+1
             do something
CASE X+2
             do something
CASE X+3
             do something
CASE X+100
             for z = 1 to 50
             i[z] = HRSIN
             next
             do something with that array.
ENDSELECT
ENDIF
GOTO MAIN
