November 24, 2024, 09:31:25 09:31
Author Topic: NEED MikroBasic Version: 1.1.6.0 crack  (Read 12511 times)
linoko
« on: May 04, 2005, 08:27:47 08:27 »
Hi friends,
does anybody have a crack for this version
Nothing is impossible
jibun24
« Reply #1 on: May 04, 2005, 09:06:17 09:06 »
Try this one
« Last Edit: May 04, 2005, 09:13:53 09:13 by jibun24 » Logged
xDigimonx
« Reply #2 on: May 04, 2005, 09:28:00 09:28 »
Thanks for sharing , jibun24
« Reply #3 on: May 04, 2005, 09:31:48 09:31 »
Hello
Very good work, we will be waiting for the newer version crack 2.0
linoko
« Reply #4 on: May 04, 2005, 10:14:00 10:14 »
Thank you friends.
The crack is GREAT.
freddyg
« Reply #5 on: May 04, 2005, 11:19:31 11:19 »
Anybody else having a problem with the mikroBasic help file?
Bring up the help screen within the mikroBasic application (eg. from the Help menu) then click on the Index tab on the left hand side (the list will be empty).
Then, if you close the help window, mikroBasic crashes (ie. the usual Microsoft " compiler for PIC microcontrollers has encountered a problem and needs to close...")
Please let me know if it works for you.
Thanks.
Freddy
freddyg
« Reply #6 on: May 04, 2005, 02:19:40 14:19 »
Please ignore the help file problem error.
I tried it on another machine and it works perfectly.
For some reason my help viewer on this machine is corrupt Sad (other help files also cause the same problem)
Freddy
