March 20, 2026, 09:03:12 09:03
Author Topic: LED Tachometer design Ideas....  (Read 8453 times)
wanderingmoose
-Given: 36
« on: May 04, 2008, 05:22:41 05:22 »
I have been working on a 20 LED tach for my motorcycle.
Build a good unit, but looking for more ideas.
The circuit I am using has a 555 timer as a frequency to voltage converter, and two LM3914 as the display drivers.
I like what I have built, but with using LM3914 as the LED drivers, it can be a little slow to respond the changes in RPM.
He hardest part so far is finding a good housing that would compliment my motorcycle.
At this time I am using a 12 volt 50 watt chrome driving light holder. Found this on Ebay.
Uses the same bulb as the halogen house lighting. MR16
So looking for any other design ideas.
Using a PIC or Huh?
Would also be interested in seeing the Silicon Chip Tachometer articles from Issue 217(PT1: Oct 11 2006) and 218 (PT2: Nov 29, 2006) that show a larger tach with LED's and 7 segment display. Like the idea of a remote display.
Thanks for your time
WM
"There is a theory which states that if ever anyone
 discovers exactly what the universe is for and why
it is here, it will instantly disappear and be replaced
by something even more bizarre and inexplicable."
"Some believe that this has already happened."
                 Douglas Adams
zuisti
-Given: 242
-Receive: 780
« Reply #1 on: May 04, 2008, 09:05:29 09:05 »
Hi wanderingmoose,
I think the slow responding is caused by your F/U converter (because you must integrate the pulses), NOT by the led drivers.
Please post here your schematic to discuss it (and make it faster :-).
Other:
At my mind the 'analog' display using 20 (or more) leds is far better in this case as a digital display using 7 segment numbers.
I think it's possible also a solution using a PIC but I'm not sure that will be plainer (and cheaper) to you...  google it!
Cheers
zuisti
sputnik
-Receive: 39
« Reply #2 on: May 20, 2008, 04:19:32 04:19 »
It can be done very easy with a pic and the proton complier.
I just built one for my bike.
Here is simple code using 16F628A, a counter to count pulses in 100ms, multiply that by 10 to get frequency (pulses per second), multiply that by 60 to get RPM.
VERY EASY!!!
Device 16F628A
 XTAL = 4
 Config INTRC_OSC_NOCLKOUT , WDT_OFF , PWRTE_ON , BODEN_OFF , CP_OFF, MCLRE_OFF ,LVP_OFF
 ALL_DIGITAL = true
 Dim rpm As Word
 Dim rpm2 As Word
  TRISB = %00000000
  TRISA = %00001100
  PORTB = %00000000
 DelayMS 100
 GoTo Mode1
 Mode1:
 rpm = Counter PORTA.3 , 100
 DelayMS 5
 rpm = rpm * 10
 rpm2 = rpm * 60
 Select rpm2
  Case 500 To 1499
   PORTB = %00000001
  Case 1500 To 2499
   PORTB = %00000011
  Case 2500 To 3499
   PORTB = %00000111
  Case 3500 To 4499
   PORTB = %00001111
  Case 4500 To 5499
   PORTB = %00011111
  Case 5500 To 6499
   PORTB = %00111111
  Case 6500 To 7499
   PORTB = %01111111
  Case 8500 To 9499
   PORTB = %11111111
  Case 9500 To  10000
   PORTB = %11111111
   PORTA.1 = 1
   PORTA.0 = 0
  Case > 10001
   PORTB = %11111111
   PORTA.1 = 1
   PORTA.0 = 1
  Case < 500
   PORTB = %00000000
   PORTA.0 = 0
   PORTA.1 = 0
 EndSelect
 GoTo Mode1
-Given: 405
-Receive: 545
« Reply #3 on: May 20, 2008, 04:40:04 04:40 »
I have that article someplace and I'LL LOOK FOR IT Grin
sputnik maybe you can post a schematic for him so he can see how much simpler it look's
wanderingmoose
-Given: 36
« Reply #4 on: May 21, 2008, 05:30:00 05:30 »
thanks for the replies.
I found the articles yesterday on the site and was able to dl.
Strange on what one will find when they are not looking.
I am waiting for 12F683 pics I ordered for a dual servo laser cat toy I am working on, to try the pic idea.
I love this site, alot of ideas and with enough people surfing the net the answers do come together.
Thanks for the replies and thoughts.
WM
                 Douglas Adams
