November 25, 2024, 02:31:52 14:31
Author Topic: [req] VisualDSP++ Release 3.5 and 4.0 Full  (Read 8262 times)
draggy
-Given: 8
« on: May 15, 2006, 06:31:29 18:31 »
hi..
requesting  VisualDSP++  Release 3.5 and 4.0 Full:
http://www.analog.com/processors/resources/crosscore/visualDspDevSoftware.html
mnasabir
-Given: 31
-Receive: 51
« Reply #1 on: May 16, 2006, 05:14:30 05:14 »
go to www.fixdown.com and search you can find both on this site
tavioman
« Reply #2 on: May 16, 2006, 08:57:25 08:57 »
Wow, I don;t understand anything on that site. Smiley
- Brain juice -
sacoroxo
-Given: 34
-Receive: 26
« Reply #3 on: May 16, 2006, 01:01:44 13:01 »
tavioman,
You may try this link -->> http://www2.fixdown.com/en/all_1.htm (the same site in english).
mnasabir
-Given: 31
-Receive: 51
« Reply #4 on: May 17, 2006, 05:23:12 05:23 »
for visual dsp 4
URL : http://www2.fixdown.com/soft/23587.asp?free=cqoltel-downs
REFRER http://www2.fixdown.com/soft/23587.asp
Den4o
-Given: 950
« Reply #5 on: May 17, 2006, 08:53:41 20:53 »
Simply change date/time to future moment before installation of package and after intallation return to original date/time.
Enjoy!
ramesh_rahu
« Reply #6 on: May 18, 2006, 04:47:03 04:47 »
hi , even beter solution...
This is my license file , it will take it for a lot of years for thedemo to expire.
# VisualDSP License File
# Analog Devices, Inc.
# Begin PACKAGE Definitions for 4.0
PACKAGE FRIO-FULL analogd 1.0 AC0CBE3719D1 COMPONENTS="ASSEMBLER-FRIO \
      COMPILER-FRIO LINKER-FRIO SIMULATOR-FRIO EMULATOR-FRIO \
      VDSP-DEBUGGER"
PACKAGE SHARC-FULL analogd 1.0 44E3CA0EFE6A \
      COMPONENTS="ASSEMBLER-SHARC COMPILER-SHARC LINKER-SHARC \
      SIMULATOR-SHARC EMULATOR-SHARC VDSP-DEBUGGER"
PACKAGE TIGERSHARC-FULL analogd 1.0 11F5CF0FA538 \
      COMPONENTS="ASSEMBLER-TIGERSHARC COMPILER-TIGERSHARC \
      LINKER-TIGERSHARC SIMULATOR-TIGERSHARC EMULATOR-TIGERSHARC \
      VDSP-DEBUGGER"
# Begin FEATURE definitions
FEATURE FRIO-FULL analogd 1.000 permanent uncounted 78AC309719AC \
   VENDOR_STRING=TST-178-346-6228484-85 \
   HOSTID=DISK_SERIAL_NUM=320d180e
NOTE: Just change the date to "permanent" and it will work
Rahu
