February 27, 2026, 03:57:50 15:57
Author Topic: Communication with PC and pic by FTI-232 and VB6  (Read 9453 times)
rollins
« on: April 28, 2008, 02:59:54 14:59 »
I'm tryng to communicate in full duplex with a pc (vb6)  and a pic 16f628
When I put a button with send command to the pic , the pc send , the pic receive and after send.
But without button it doesn't work
someone has in the past the same problem ?
Best regards* Huh
locus
-Receive: 15
« Reply #1 on: April 28, 2008, 03:56:28 15:56 »
You may need to put a delay routine for the PC
Ahmad_k
SCG Moderator
-Given: 178
-Receive: 1299
« Reply #2 on: April 28, 2008, 05:03:09 17:03 »
Put your code here to check it.
rollins
« Reply #3 on: April 29, 2008, 08:59:41 08:59 »
Thanks but the delay is not important, the problem I Think is when you use the commevent, you can't put a send statment in case of receive for exemple
t
Posted on: April 29, 2008, 09:51:20 09:51 - Automerged
Here vb code:
Private Sub Comm1_OnComm()
Select Case Comm1.CommEvent
    Case comEvReceive
    byterec = Comm1.Input
    If Asc(byterec) = 13 Then
        fin = Len(Text1.Text)
        temp = Val(Text1.Text)
        ' here the code for data treatment
        Text1.Text = ""
        '   Here I want to put a send statment but nothing append !!
        Comm1.Output = Format(adress, "00000") & Chr(0) & _
                Format(ordre, "000") & Chr(0)
    Else
        Text1.Text = Text1.Text + byterec
    End If
End Select
 Huh
End Sub
Ahmad_k
SCG Moderator
-Given: 178
-Receive: 1299
« Reply #4 on: April 29, 2008, 10:53:43 10:53 »
I think this code wait for data receive (byte : 13) if it is received then the PC send the required string. So it will not work like you said.
In your first post you said that the PC send first and then PIC respond, so now the PIC is not respondind because the PC isn't sending anything. If you can also put you PIC code.
locus
-Receive: 15
« Reply #5 on: April 29, 2008, 11:28:06 11:28 »
The problem is that you try to send a message from within the receive event.
The receive event should finish first before a send command can be issued.
This is because the oncomm event handles both send and receive events
Try put a timer.
Ahmad_k
SCG Moderator
-Given: 178
-Receive: 1299
« Reply #6 on: April 29, 2008, 02:55:54 14:55 »
Try put a timer.
This is what i talking about, but we must be sure from his code to be ok, and then use a timer on visual basic.
sherm
« Reply #7 on: April 29, 2008, 03:08:55 15:08 »
Go here and look at these two excellent examples of how to communicate between a PC and PIC using VB6 and PicBasic Pro. They're both good code for basing your own applications on.
Sending data from a PC ... http://www.rentron.com/sending_data.htm
Receiving data from a microcontroller ... http://www.rentron.com/receiving_data.htm
rollins
« Reply #8 on: April 29, 2008, 04:30:53 16:30 »
Thanks but I don't know why I 've been put down with restriction !
Would you please send link to me by email at [email protected]
best regards
Posted on: April 29, 2008, 05:20:44 17:20 - Automerged
to Ahmad_k
No at first I ask to the pic to answer and after, it's would be automatic.
You right for the commevent behaviour, so I can use a timer , but do you think that It could be possible to work without a
MSCOMM ?
 best regards
Ahmad_k
SCG Moderator
-Given: 178
-Receive: 1299
« Reply #9 on: April 30, 2008, 08:35:55 08:35 »
For my projects i use MSCOMM_OnComm() only for initializing and then i use Timer on VB, on each timer overflow, i check i check the InBufferCount size to see if the whole data has been received if yes i respond with some fonctions and procedure calls.
When you use TIMERS in your VB code the usage of the CPU will be lower. So keep going and we are here to help you.
rollins
« Reply #10 on: May 05, 2008, 09:54:17 09:54 »
Thank Ahmad , I will have a look on this method and I keep you in touch
Many thanks again
Posted on: April 30, 2008, 04:35:22 16:35 - Automerged
To sherm
Not able to get the link, would you please send it to me by mail at [email protected]
UNIDIFF
« Reply #11 on: May 05, 2008, 10:12:57 10:12 »
What is a Fti 232 Huh do you means FT-232 from FTDI Huh
br
rollins
« Reply #12 on: May 05, 2008, 10:48:12 10:48 »
Ho yes FT-232 from FTDI,
