Dr Caos
« on: April 23, 2008, 04:41:01 04:41 » |
Im going to build a machine that fill a bottle with soda but I need a bit of help with the fluid level sensor. Can you tell me what sensor its the best for that purpose?
-Given: 496
« Reply #2 on: April 24, 2008, 01:11:33 01:11 » |
Fuel level sensor for car fuel tanks are easy to get.
Dr Caos
« Reply #3 on: April 24, 2008, 06:30:38 06:30 » |
Interesting... I need a not invasive way to sense the level. So, I will use ultrasonic. Ty And Ty Parmin.
zokij
-Given: 269
-Receive: 679
Nice time :)
« Reply #4 on: April 24, 2008, 11:05:22 11:05 » |
BTW Here is some nice page for you LIQUID LEVEL TRANSMITTER/RECEIVER SYSTEM with 16F628 at address: http://www.vermontficks.org/pic.htm nice time
otter
-Given: 200
« Reply #5 on: April 24, 2008, 10:31:37 22:31 » |
If the container is non-conductive, you could use a capacitive sensor on the outside of the container. Have a look at the Analog Devices web site for devices/app notes.
ucup
« Reply #6 on: April 28, 2008, 06:06:21 06:06 » |
Yes, I have already sense a water in the pipe by capacitive sensor and it work. Mybe you can try it.
LSSB
« Reply #7 on: April 29, 2008, 08:53:54 20:53 » |
I agree capacitive sensors make good level indicators. Make sure you calibrate at both full and empty container. Ultra sonic can be expensive.
tuvoj
« Reply #8 on: April 30, 2008, 07:57:41 07:57 » |
If container is IR pass-through and liquid does not have the save dispersive qualities as air, you could also use an IR transmitter/rcvr pair to sense difference in reflectivity at a certain level, then trip some downstream logic off of this...
This would work with very little cost, and could be positioned at any level, from the outside if the container...
Cheers-Tuvo
boss.lrc
« Reply #9 on: May 05, 2008, 07:25:00 19:25 » |
Hi zokij
Can this LIQUID LEVEL TRANSMITTER/RECEIVER SYSTEM with 16F628 be used in a container with gas? or there is a danger of explosion
zokij
-Given: 269
-Receive: 679
Nice time :)
« Reply #10 on: May 08, 2008, 12:36:17 12:36 » |
Hi zokij
Hi boos.lrc possibility of explosion dependence of gas kind, old petrol station was use similar sensor .... but perhaps you can use some other sensor... specify which gas you use in what application and I will try to found some nice solution for you
juliano_cps
« Reply #11 on: May 19, 2008, 05:35:57 05:35 » |
you are going to use a commercial solution ? or do it yourself ? if DIY: Nicera Japan manufactures selated US transducers (used in parking car radars) you'll need only one... the receiver and transmitter are the same ! if you live in Brazil I could point you where to buy... bye.
alspa
« Reply #12 on: May 20, 2008, 05:09:45 05:09 » |
You could also use weight. Use a cheap and simple weigh scale under the soda bottle to measure weight, convert this to volume is easy.
You will struggle with techniques to measure level as most will want to be inside the bottle and the other most common method is using differential pressure which for a soda bottle is very small.
Most bottling companies use a simple timer as the same amount of liquid will flow all the time and they are quality controlled with weight.
Cheers, Alspa
