November 25, 2024, 08:37:33 20:37
Author Topic: Looking for voltage control amplier circuit  (Read 3465 times)
Epegic
« on: April 18, 2008, 08:35:07 08:35 »
Are there any simple circuit using ordinary op-amp or transistores whose gain is proportional to control voltage applied.
Thanks,
aProgrammer
-Given: 70
-Receive: 258
« Reply #1 on: April 18, 2008, 10:48:39 10:48 »
A more easy way is to use an OTA
like CA3080, LM3080, NE5517, LM13600 or LM13700, BA6110, CA3280...
hugo
« Reply #2 on: April 19, 2008, 02:32:56 02:32 »
Microchip has some digitally controlled VGAs , they are very good and easy to use.
ar3000a
« Reply #3 on: May 08, 2008, 06:47:46 06:47 »
Use a FET to replace the feedbak resistor,One op-amp circuit can be voltage-controled.
Posted on: May 08, 2008, 07:41:59 07:41 - Automerged
Or a DAC can do it well.http://2008sfile.ic37.com/2008file/tech/2008-2-10/0210200145_10931_1.jpg
Epegic
« Reply #4 on: August 10, 2008, 03:30:20 03:30 »
"Use a FET to replace the feedbak resistor,One op-amp circuit can be voltage-controled."
ar2000a, please suggest some circuits.
arash_tah
« Reply #5 on: August 10, 2008, 05:07:20 05:07 »
Hi all
I see what u want
The best thing is using an analog multiplier u can apply your signal to one pin and your control signal to another pin the output will be the multiplicatrion of bouth signal
beque
-Given: 51
-Receive: 149
« Reply #6 on: August 11, 2008, 04:35:22 16:35 »
Use this
http://www.analog.com/static/imported-files/data_sheets/AD633.pdf
It Works fine !
