April 26, 2025, 01:12:37 01:12
Author Topic: Velleman K8000  (Read 3978 times)
trampe
-Given: 527
-Receive: 261
« on: April 05, 2008, 08:30:56 08:30 »
Specifications
    * digital outputs:
          o optocoupler, open collector output: 50mA - max. 30VDC
    * digital inputs:
          o optocoupler input: 5V/5mA, max. 20V/40mA
    * analogue outputs:
          o 8 outputs DAC1 to DAC8, resolution: 64 steps
          o minimum output voltage: 0.1V at 2mA
          o maximum output voltage: 11.5V adjustable at 2mA
          o resolution per step from 0.1 to 11.5V: 160mV +/- 90mV
          o 1 precision output DA1, resolution: 256 steps
          o minimum output voltage: 0V
          o maximum output voltage: 4.5V adjustable at 0.5mA
          o resolution per step from 0 to 4.5V: 17.5mV
    * analogue inputs:
          o 4 analogue inputs AD1 to AD4, resolution: 256 steps
          o minimum input voltage: 0V
          o maximum input voltage: 5V
          o input impedance: 50Mohm
          o resolution: 19.5mV
    * communication protocol: I²Cbus
    * LED indication for each I/O
    * 25 pin D series connector for computer
    * 25 pin D series connector for printer
    * supply voltage: 6vac and 15Vac
    * PCB dimensions: 237 x 133mm (9.3" x 5.2")
I have made a PCB (in PDF and Altium Designer formate).
I will design a smaller PCB in a few days.  This project can be used with ProfiLab.
http://rapidshare.com/files/104987402/Velleman_K8000.zip
Trampe
« Last Edit: April 05, 2008, 10:42:06 10:42 by trampe » Logged
-Given: 405
-Receive: 545
« Reply #1 on: April 05, 2008, 03:37:40 15:37 »
Really nice work there Trampe,good project that I could really use.the smaller pcb your talking about is it going to be mostly surface mount or through the hole?
trampe
-Given: 527
-Receive: 261
« Reply #2 on: April 27, 2008, 07:21:28 19:21 »
All IC vil be DIL (through the hole) and also every capasitors (except 100nF).
 Resistors will be 1206 (SMD) If you have problem to get the TDA8444 (DAC) then try Cricklewood Electronics Ltd  ([email protected] ) costs £2.50
Trampe
Posted on: April 27, 2008, 07:19:42 19:19 - Automerged
Trampe
