March 10, 2026, 09:52:39 09:52
Author Topic: ispLEVER Classic  (Read 7189 times)
itp
-Given: 225
-Receive: 20
« on: April 03, 2008, 03:27:16 15:27 »
Hi All,
I am using ispLEVER Classic for programming Lattice GAL16V8d chip. I am new to this software.
I have following doubts.
1. How can I edit the  Constraint to decide the PINs.
2. How can I do PIN locking (This means physical pins should not change if I modify my code)
3. Any other software other than ispLEVER is available for this chips.
Thanks and regards
Itp
avralam
-Given: 153
-Receive: 30
« Reply #1 on: April 04, 2008, 02:18:32 14:18 »
Use search button in this forum! Gal and pal
harri_el_sucio
« Reply #2 on: April 04, 2008, 11:45:39 23:45 »
hello itp:
Sorry for my language.
I programme in ABEL
And it is very simple
In the example later
In the list in Lenguage ABEL the arrow indicates the wished feet
Also the same thing can be done if you draw a scheme in ispLEVER Classic
Can send a simple scheme if you programme in scheme
Example:
MODULE Contador_binario_gray
TITLE 'Contador en Gray'
"Pins Input
clk, M, RESET pin 2, 3, 4;   <------------
"Pins Output
Z0, Z1, Z2 pin 17,18,19 istype 'pos, reg'; <-----------
"Status Register
SREG = [Z0, Z1, Z2];
S0 = [0,0,0];
S1 = [0,0,1];
S2 = [0,1,0];
S3 = [0,1,1];
S4 = [1,0,0];
S5 = [1,0,1];
S6 = [1,1,0];
S7 = [1,1,1];
equations
[Z0,Z1,Z2].clk= clk;
[Z0.ar, Z1.ar, Z2.ar] = RESET;
state_diagram SREG
state S0: goto S1;
state S1: if M then S3 else S2;
state S2: if M then S6 else S3;
state S3: if M then S2 else S4;
state S4: if M then S0 else S5;
state S5: if M then S4 else S6;
state S6: goto S7;
state S7: if M then S5 else S0;
test_vectors ([clk, RESET, M] -> [Z0, Z1, Z2])
[0,1,.X.] -> [0,0,0];
[.C.,0,0] -> [0,0,1];
[.C.,0,0] -> [0,1,0];
[.C.,0,1] -> [1,1,0];
[.C.,0,1] -> [1,1,1];
[.C.,0,1] -> [1,0,1];
[.C.,0,0] -> [1,1,0];
[.C.,0,0] -> [1,1,1];
gem1144aaa
-Given: 134
-Receive: 27
« Reply #3 on: April 16, 2008, 10:15:16 22:15 »
hello itp:
I programme in ABEL
Example:
"Pins Input
"Pins Output
"Status Register
S0 = [0,0,0];
S1 = [0,0,1];
S2 = [0,1,0];
S3 = [0,1,1];
S4 = [1,0,0];
S5 = [1,0,1];
S6 = [1,1,0];
S7 = [1,1,1];
equations
state_diagram SREG
state S0: goto S1;
state S6: goto S7;
Can you share your ABEL copy or send a link for it
jack12345
-Given: 59
-Receive: 134
Happy diy
« Reply #4 on: April 17, 2008, 02:17:40 14:17 »
HI:
I found abel Links:http://www.elektroda.net/download/file201.html
However, I have not used!
harri_el_sucio
« Reply #5 on: April 23, 2008, 10:23:35 22:23 »
Hi : gem 1144aaa
The collector of ABEL this one included in ISPLever 5.1
The ISP Lever 5.1 that I use this one in :
http://www.sonsivri.com/forum/index.php?topic=4011.0
And OK works
