April 05, 2025, 09:25:18 21:25
Author Topic: 18F458 with Proton  (Read 16994 times)
LazBoy
-Given: 78
-Receive: 25
« on: May 02, 2005, 02:35:14 14:35 »
Dear Friends,
I used 16F877 with a project. I decided to use 18F458 with same project. Because of less memory on 877. But, when I compile the source file,
it seems larger than 877 file. For example, same file compiled for 877
8k, for 458 it larger such as 13k. And it seems not run properly.
Do you use Proton 2.1.3 with 18F series ? Any problem ?
I think Proton 2.1.3 buggy for 18F series. Any suggestions please.
« Reply #1 on: May 02, 2005, 02:46:48 14:46 »
Hello Fellow
Try to use Proton+ Compiler 2.2 Beta 8, it work better for 18F series.
bye  Smiley
LazBoy
-Given: 78
-Receive: 25
« Reply #2 on: May 02, 2005, 03:59:31 15:59 »
Yes, I tryed. Some problems fixed but not all.
And also compiled size same, 13k. Is this normal ?
momotot
« Reply #3 on: May 02, 2005, 07:18:04 19:18 »
Hi LazBoy,
Don't forget  13K are 13K byte for 458 PIC  and the 8K are 8K word  for 877 PIC !
momotot
LazBoy
-Given: 78
-Receive: 25
« Reply #4 on: May 02, 2005, 07:37:01 19:37 »
momotot;
Could you explain more details please ?
Is this 16Bit MCU differencies ?
-Given: 561
« Reply #5 on: May 02, 2005, 08:07:06 20:07 »
what's your code to you are trying to complie send it over and i will try it on mine PDS and can also sim it in protteus and real life
the 18f series is a better pic
wizpic
momotot
« Reply #6 on: May 02, 2005, 08:34:32 20:34 »
Lazboy,
PIC16F877 is a 14 bit core device while PIC18F458 is 16 Bit core device, the Program memory of  the 14 bit core is organized as a 14 bit word  which is something between the byte and the word, while the 16 core  code memory is organized in bytes but each instruction uses 2 bytes.
To compare the size of your programs you should  divide the size of  the 18 series PIC by 2, you may wonder what is the benefit of the 16 bit organization, if  each instruction will have a word.  ( 14 bit  or 16 bit ), the advantage will be clear if you look at the data storage in the code memory, any byte size data stored in 14 core PIC will occupy one WORD, while it will occupy only one byte in the 16 core PICs, this and in addition to better  memory organization  and other features, make the code generated for 18 series lesser and more efficient than 16 series.
momotot
LazBoy
-Given: 78
-Receive: 25
« Reply #7 on: May 03, 2005, 05:32:53 17:32 »
Momotot, thanks for detail explanation.
Wizpic, I will do that using my friends PDS soon, thanks.
