January 10, 2025, 09:20:48 21:20
Author Topic: SD/FAT with ccs libraries.  (Read 7934 times)
wATAw
« on: March 10, 2008, 10:14:59 10:14 »
I am working in a project, where i have to write a sd card in FAT. So i would like know someone, who has worked with the libraries you can found in the lastest versions of CCS. And which is the electronic circuit you could use to get it?
Sorry about my english!! I would be very grateful!!
Posted on: March 07, 2008, 10:09:59 10:09 - Automerged
Anybody can help me please??
petarp
-Receive: 51
« Reply #1 on: March 10, 2008, 02:56:01 14:56 »
Hi. Look here:
http://www.ccsinfo.com/forum/viewtopic.php?p=76808&sid=056aeea56d0db84d06c44df322327843
Best Regards.
wATAw
« Reply #2 on: March 11, 2008, 09:38:05 21:38 »
I cant still see the links. But in few day i hope i will see it!!!thank you!!
mayler
Roger that!
« Reply #3 on: March 12, 2008, 12:10:39 00:10 »
It's a link on ccs forum... Make a search there. In the examples folder of ccs has a ex. with fat system.
Computer Engineer.
Fred1
« Reply #4 on: March 12, 2008, 04:55:21 04:55 »
I have used the ccs fat routines with a sd card.  They don't work properly!
Their example seems like it works, but any files written to the sd card cannot be read on a PC.  I was using fat32 filesystem.
I would suggest finding another filesystem (or wait unitll ccs fix theirs!)
wATAw
« Reply #5 on: March 12, 2008, 09:30:13 09:30 »
Thank you very much!!
And what pic do you use?? i want to do it with pic18f4550, and i know that i need voltage dividers in CS,CLK and SDO, but i would like to know if is necessary something in SDI, to convert the 3.3 high level to 5 high level.
I don´t know if i have explained well because my english isn´t the best.... Cry Cry
I am trying to find the link you say me.
Thank you!!!
Fred1
« Reply #6 on: March 13, 2008, 03:21:39 03:21 »
Thank you!!!
I used a 18f67J11 running at 3.3V, so level translation wasn't necessary.  You are going to have to run a level converter for the SDI pin - it needs a minimum (Vih) of 3.5V on a PIC running at 5V.  A pullup to the 5V supply could damage the memory card, so a simple resistor won't work!  One of these (SN74AHCT1G125DBVR) should do the trick.
Your english is fine, btw!
wimpoh
« Reply #7 on: March 20, 2008, 07:31:57 07:31 »
Can I find about format Fat32 in sd or mmc card?
I will use 18F452 make data logging from DO pobt.
and use sd or mmc card.
