Hi everyone,
Couple of days ago I started to search CCS code for Philips RC5 decoder (I'm really lasy coding for IR
)...I found different source codes for it, but most of them uses interrupt routines in them...Couple of hours of searching i found this awsome code and wanted to share with you...I tryed to contact with author (
nickname: yager) about share his code but he did'd reply my messages (it was posted on edaboard forum in 2001), i hope nobody gets mad on me
The code is originally developed for PIC12F629 @ internal 4MHz OSC and I/O ports are GPIO0=TX, GPIO2=IR...36~38KHz IR Receiver is fine to receive clear data (I suggest TSOP1736)...Output is serial data @ 9600bps,None parity,8bits...When the IR data receive by 12F629, it brusts the corresponding "Address" and "Data" from GPIO0...
Yager wroted down really nice routines for Manchester decoding, the code calibrates the timing every time
...If you modify the code little bit, you can easly decode IR data stream under 32~455KHz carrier...But i still did't test for it (I told you, i'm lasy for IR
I've personally tested his code from 10 meters
and 24 hours
by connecting the circuit to my PC via USB (with FT232) + Simple VB program, I did'd receive any single false data...That means CODE WORKS PERFECT!!!
Thanks Yager for this awsome code...I hope you enjoy it...This code really Rocks
SAINT...
Posted on: 04 March 2008, 14:01:16 - Automerged
Upto now, readed 81 times, downloaded 52 times but NO FEEDBACKS
