November 23, 2024, 08:21:40 20:21
Author Topic: Pic sound record  (Read 5998 times)
selim
« on: March 04, 2008, 07:49:10 07:49 »
HI ALL
need help .any picbasic pro source code to pic Microcontroller sound record
with eeprom memory chip.
Thank you in advance
ABBOSE
-Receive: 21
« Reply #1 on: March 04, 2008, 11:56:37 11:56 »
See the topics http://www.sonsivri.com/forum/index.php?topic=5626.0
gedonet
-Given: 20
« Reply #2 on: March 11, 2008, 03:57:45 03:57 »
Go to this site http://www.romanblack.com/picsound.htm their are a lot of explanations not in basic but its not complicated i test it with a 16F88 in assembler without EEprom all data a in flash memmory with long jump and big table.
Gilles
centiane
« Reply #3 on: March 11, 2008, 11:45:48 11:45 »
for record sound easy and low cost you are use a chip ISD25XX , the xx is the time, this chip use a 05, 15, 30 ,60 and 120 Seg of record, and the interface for record and play is very easy implementation, into of datasheet aplycation note wiht diagram for your use.
Good look Centiane.
mhayball
« Reply #4 on: March 12, 2008, 11:28:21 23:28 »
Are you wanting PIC to do everything or do you want to control an external chip like a sound recording IC?
cooperharris
-Given: 72
-Receive: 22
« Reply #5 on: April 22, 2008, 06:53:03 06:53 »
HI ALL
get this  http://www.winbond-usa.com/mambo/content/view/36/140/   and  you are  done!,  it is  easy if  yoyu get  this IC, because  with just a pic  you are never  going to  get to record  something  with quality
aartb
« Reply #6 on: May 07, 2008, 02:05:13 14:05 »
hi
 see datasheet of ISD33240
