April 12, 2026, 01:36:26 01:36
Author Topic: Urgent help from the professionals  (Read 6560 times)
orcasdeveloper
« on: March 01, 2008, 09:00:59 09:00 »
I am working in combination lock alarm system, in short
1- once the operator opens the door  a timer has to be started and counts a configurable time period
2- if the time period elapsed and correct password entered no alarm will be raised else alarm will be raised and
operator has to enter the correct password to disalarm the system
3- in case the operator want to close the door, he enters an exit code and immediatley the timer will be startted once more time for a configurable time period after elapsed if the door still opened the system will trigger the alarm untill the door got closed
4- the system has an operator/password and engineer/password accounts and the engineerr has the
ability to change passwords and alarm periods
_________________________________________
the problem facing me is that microcontroller doesnot support multitasking
i first used proton without result
iam currentlly use picbasic pro with darrel taylor instant interrupt system
and have confusing problem
the timer works if i didnot enter any password(4 character length) but once i start typing password characters before alarm raised the last character got stucked and the alarm raised without reasonable cause
 i wish to find solution to this problem with the aid of ou greats and happy return back for the forum
Ahmad_k
SCG Moderator
-Given: 179
-Receive: 1299
« Reply #1 on: March 01, 2008, 02:40:39 14:40 »
Upload your code here to check it
-Given: 582
« Reply #2 on: March 01, 2008, 05:57:33 17:57 »
I have a simular thing and use proton, With out problems multi tasking and the same thing goes for quite a few projects that I have working, It may be a problem with your code
wizpic
fernandodiaz
« Reply #3 on: March 01, 2008, 11:04:11 23:04 »
HI YOU CAN MAKE YOUR PROJECT WITH PARALLAX PROPELLER  THIS PROCESSOR HAVE INTERNL 8 CORE
(8 PROCESSORS INDIVIDUAL AND NO NEED INTERRPTS YOU CAN ASIGN EACH PROSESSOR TASK DIFERENTS WITHOUT INTERRUPTS WITH COMPILER SPIN VERY EASY PROGRAMMING
www.parallax.com
zokij
-Given: 272
-Receive: 700
Nice time :)
« Reply #4 on: March 01, 2008, 11:55:53 23:55 »
www.parallax.com
Hi Huh
If he use PARALLAX then  Roll Eyes is better if he buy alarm like paradox  Undecided (will be cheapness)
Or if he have much money he can jettison  Wink ...
orcasdeveloper make good decision Shocked but need little practiced ...  Cheesy and help
caveman508
-Given: 12
READ, REAd, REad, Read
« Reply #5 on: March 02, 2008, 06:12:35 06:12 »
Multi-Tasking
This is a subject with many answers.....
Look at the screen you are reading this on, while you have several other "windows" open right now.....
How many processors are in your PC???
Hit Ctrl-Alt-Del for a list of all of the other "tasks" that are running in the background??
orcasdeveloper, Please understand that all processors are capable of multi-tasking, it is just a matter of programming style.  I have written all of my programs based on the style of multi-tasking.
Consider this:
Create a timer interrupt routine that decrements a variable.  Call it isr_delay_1
Now do something like this:
Do_Something();
isr_delay_1 = 45;
while(isr_delay_1);
Do_Something_New();
What you have done is create a delay between Do_Something and Do_Something_New that will be 45 times the timer interrupt rate.  OK?  COOL!!!
Pretty simple, YES.  But what IF you do 15 other things while waiting?
With further questions, I will be happy to expand on this subject.  The details are a bit long in explanation, but I will do my best to explain.
Think of this example:
Flash 5 LEDs at different rates, read a keyboard, read 5 analog channels, send serial data of current status at a regular update rate and write to an LCD display.  Do all this while maintaining a real-time clock, handling alarms and time-outs along with whatever you choose to add to the list of TASKS you want.
Please understand this is easy, but it is a different style (a different way) of programming.
Just let me know if you want to learn how to do this with the SMALLEST processor you can think of.
Be aware: There is no limit to what you can do, just imagine it, create it and DO IT.
I will be watching for your response.
Just imagine,
the Caveman smiles
orcasdeveloper
« Reply #6 on: March 02, 2008, 10:24:39 10:24 »
CHECK ATTACHMENT
Posted on: March 02, 2008, 11:16:23 11:16 - Automerged
HI WIZPIC
I GUESS POST AN EXAMPLAR  CODE USING PROTON CAUSE IAM TRIED PROTON HOPELESSLY
THANKS IN ADVANCE
WAIT YOU
Posted on: March 02, 2008, 11:21:06 11:21 - Automerged
HI SMILY CAVEMAN
I URGE YOU TO CODE REAL ONES
I AM WATCHING
sohel
-Given: 169
-Receive: 149
« Reply #7 on: March 03, 2008, 01:36:59 13:36 »
all programmer know that what did u flash here.  thanks for universal truth.
Multi-Tasking
Consider this:
Do_Something();
isr_delay_1 = 45;
while(isr_delay_1);
Do_Something_New();
Just imagine,
the Caveman smiles
caveman508
-Given: 12
« Reply #8 on: March 05, 2008, 02:30:30 02:30 »
sohel,
Thank-you for your reply.  I am new to this forum, and enjoy sharing knowledge, comments and ideas.
This forum has a feature new to me, that is, the "Thanks" button.  I have received a few and I thank-you all in return.
I am not sure of your use of the word "flash".  I take it to mean "post" as in my reply.
The Best to You,
Caveman
JohnnyT
« Reply #9 on: March 25, 2008, 02:03:53 02:03 »
correct me if I am wrong but I believe that it is necessary to make sure that each of your tasks can complete within the given task time to use that without problems.
