November 30, 2024, 12:55:54 00:55
Author Topic: [question] : virtual ground ?  (Read 2916 times)
omidsht
-Given: 60
-Receive: 16
« on: February 28, 2008, 07:37:38 07:37 »
Hi ,
i have two differential signals , when one is +6 the other is -6 , and vice versa , and when one is null the other is null too . i want to build a virtual ground for them to compare them to that virtual ground , (actually i want to rectify them and take them to microcontroller , so i nee d a ground and i dont want to take a gnd line from the source) , can any body suggest a circuit to buld a virtual ground for them ?
thanks
omid
 Wink
Posted on: February 27, 2008, 06:48:06 18:48 - Automerged
no body can help me ?
 Huh Cry
bajrang
-Given: 245
-Receive: 79
« Reply #1 on: February 28, 2008, 08:52:10 08:52 »
Dear friend,
please look at the schematic attached.
Hope it solves your problem.
regards,
FriskyFerret
-Given: 513
-Receive: 360
Put it in, take it out.
« Reply #2 on: February 29, 2008, 02:23:41 14:23 »
(actually i want to rectify them and take them to microcontroller)
Is that plus and minus 6 volts AC or DC?
omidsht
-Given: 60
-Receive: 16
« Reply #3 on: March 02, 2008, 04:28:35 04:28 »
that shematic does not work , it has a lot of noise on output , we have + and - 6 volt as a pulse wave (dc) with frequncy of 100khz .
the above shematic did work in simulation but not in real .
so to have a test , i just used two 33k resistors in series , one end 6 volt fiexed , the other end -6 volt fixed , then i put the gnd of oscope in the middle of those two resistors (which should be zero accordinf to kvl) and the probe of oscope on the +6 volt end , it was really noisy .
why ?
i dont know !
and this is why the above circuit does not work for me .
any oppinion ?
thanks
omid
caveman508
-Given: 12
READ, REAd, REad, Read
« Reply #4 on: March 02, 2008, 05:11:09 05:11 »
I am not an analog engineer, but I see no capacitors in the design..  Maybe some on the supply, and a bit on the voltage divider???
Just a guess, they do amazing things.
Caveman
