November 25, 2024, 10:45:10 10:45
Author Topic: SD Card Read & Write  (Read 6238 times)
zawmintun1
-Given: 2139
-Receive: 26
« on: February 20, 2008, 12:56:39 12:56 »
How to
SD Card 512 MB with PIC Microcontroller for Reading and Writing
Please help me as Proteus Projects design Files
Thank a Lot
adamhorden
« Reply #1 on: February 20, 2008, 09:27:18 21:27 »
There is some good information here http://www.captain.at/electronic-atmega-mmc.php It explains about SD cards in that artical and how to read and write to them with a micro controller,
Hope this helps,
Adam
mitaka
« Reply #2 on: March 28, 2008, 12:57:03 00:57 »
you can use this code :
http://efsl.be/
basically you only have to write a function that writes and reads a buffer.
« Last Edit: March 28, 2008, 01:01:59 01:01 by mitaka » Logged
wichayen
« Reply #3 on: April 02, 2008, 03:51:26 03:51 »
SD Card can communicate with SPI interface.
There have some book that expand about SD card interface with PIC. If you search for
"Programming 16-Bit PIC Microcontrollers" in this borad you can find.
Note: This book also give the concept of FAT16.
cooperharris
-Given: 72
-Receive: 22
« Reply #4 on: May 22, 2008, 12:44:03 12:44 »
any one got a exact page  for the  whole project  using pic?
Walkura
-Given: 56
-Receive: 82
« Reply #5 on: May 23, 2008, 12:29:08 12:29 »
Some time ago i downloaded a proteus sim with a sd card and as it turned out its from Sonsivri.com .
http://www.sonsivri.com/forum/index.php?topic=6658.0
Have a look at this maybe this will get you on track .
Good luck Walkura.
eoasap
-Given: 39
-Receive: 43
« Reply #6 on: July 29, 2008, 02:57:11 14:57 »
If you want to read/write from the SD card, you must know the SPI protocol, that's it.
However, If you want to make it compatible with windows (linux, etc..) you must adhere to the FAT
format which is very complex. You can either spend a year learning it, or you can use off the shelf
chips that contain the fat stack.
Alfat is one of several companies that create a system where you communicate using DOS-like
commands and UART to write the code and the chip handles the FAT.
Homepage
http://www.alfat.co.uk/
Project Examples (Mine is 2nd from bottom, the GPS logger)
http://www.alfat.co.uk/projects.html
Joe_jj
« Reply #7 on: August 01, 2008, 03:23:03 15:23 »
Search in the lab electronic forum (proteus supporter site).
There are some topic talk about that.
