November 25, 2024, 11:40:05 11:40
Author Topic: Picbasic Pro JDM Programmer  (Read 45737 times)
robtbldr
« on: February 19, 2008, 12:53:44 00:53 »
Just got a serial JDM Programmer on ebay and can't figure out how to get picbasic pro to communicate with it through microcode studio.  Any ideas?  I tried to add it under compiler options but then it asks me for executable name.  No idea what to add.  Thanks for any insights.
pomidor
-Given: 36
-Receive: 90
« Reply #1 on: February 19, 2008, 08:38:56 08:38 »
You can simply use IC-Prog with your .hex generated by PBP and JDM
http://www.ic-prog.com/
if you can't see links - try google for IC-Prog
robtbldr
« Reply #2 on: February 19, 2008, 11:10:46 23:10 »
I understand that I could use IC Prog, but I would like to see if I could cut down a step and program through picbasic.  But I appreciate your help.
ta41
« Reply #3 on: February 21, 2008, 07:48:09 19:48 »
are there ajdm programmer capability 18f452 ?
thanks
cepa
-Given: 201
-Receive: 708
« Reply #4 on: February 23, 2008, 06:09:35 18:09 »
In microcode studio plus ( IDE of picbasic pro ) you can install new programmer and software ....
and yes a 18f452 is supported by the JDM ..
murugan
-Given: 24
« Reply #5 on: February 25, 2008, 07:58:04 07:58 »
any one help me . i have jdm programmer but my laptop dosnot having a serial port how to connect and program my pic . i have only usb port and printer port
microled
-Given: 15
« Reply #6 on: February 26, 2008, 02:47:48 02:47 »
View
     Compile and Program Options
                    Programmer
Select Add New Programmer
      Select Create a custom programmer entry
Follow on Screen directions
and your programmer will be used by MCS.
edi14_10
« Reply #7 on: February 27, 2008, 08:43:48 08:43 »
For laptop that doesn't have any serial port, we can use USB to serial converter. or you can try to make one. try to visit this website :http://www.recursion.jp/avrcdc/
DINESHjp
« Reply #8 on: September 12, 2008, 01:50:37 01:50 »
for laptop u cannot use usb to serial converter ,  jdm programmer   takes its power from the serial port
it needs as much as 12 volt for mclr pin.  u can not get this much voltage through usb to serial converters.
newboy
-Given: 42
-Receive: 20
« Reply #9 on: September 12, 2008, 06:41:36 18:41 »
I use this "blueroomelectronics_pickit_2_lite_2075.pdf"  schematic and working 100%.
URL ... http://www.sonsivri.com/forum/index.php?topic=10670.0
qz
« Reply #10 on: September 13, 2008, 05:06:32 17:06 »
You can try to use the USB PIC programmer at this site : http://www.instructables.com/id/GTP-USB-PIC-PROGRAMMER-Open-Source/
Its DIY and easy to follow. Or you can buy a commercial programmer like this: http://www.electronickits.com/kit/complete/prog/ck1711.htm
« Last Edit: September 13, 2008, 05:07:48 17:07 by qz » Logged
