December 14, 2025, 10:42:50 22:42
Pages: 1 [2] 3 4  All
Author Topic: PicKit2 Clone  (Read 58327 times)
-Given: 853
-Receive: 4420
« Reply #25 on: September 10, 2008, 07:16:16 19:16 »
You did not draw from original scematic, if you did you would have the opamp that allows you to program at the right voltage for the device your using. you used the same scematic as blueroom clone, with that you can only program your devices at 5 volt. also you left off the two eeproms that allow you to program away from a pc, with only a pickit2 and power supply.
I think being able to program at 3.3 volts is very inportant, it's now common to use 3.3 volt devices and 99% of the pic work I do is at 3.3 volt.
as for my nic better to use that, and not my real name, least my employer and crownhill would know my real name.
selim
« Reply #26 on: September 11, 2008, 06:14:48 18:14 »
I have a GTP-USB Plus hardware .
I programmed the pic using  the PICkit2_FWv2.hex (PicKit2 modified firmware),
 but a probleme accured with the driver(usb device not recognized)
please advice
thank you in advance
charudatt
-Given: 53
-Receive: 70
« Reply #27 on: September 11, 2008, 07:07:57 19:07 »
Ogul,
Do you have a photograph of your finished project. That would be really appealing for some one to pursue it.
newboy
-Given: 42
-Receive: 20
« Reply #28 on: September 11, 2008, 08:31:50 20:31 »
Yes,I use the pdf as the same scematic as blueroom clone.
Yes,as I only use 5V as programmer for PIC18F and PIC16F.
Which PIC you use for 3.3V ?
hemlig
Translator
-Receive: 50
« Reply #29 on: September 11, 2008, 09:54:33 21:54 »
@newboy
Have a look at this link: http://www.microcontroller.com/news/microchip_nanowatt_pic16f.asp
This has been there since Mar 3, 2003 - 8:58:00 PM
New Microchip PIC16 New Low-Power Microcontrollers with nanoWatt Technology
"Power consumption of less than 1µA is available in standby mode. Operating voltage range is 2.0 to 5.5 volts"
If it work don't fix it!
MAXPAYNE
-Given: 510
-Receive: 373
It's a little funny......
« Reply #30 on: September 12, 2008, 10:52:21 10:52 »
please advice
do u have gtp usb plus firmwire ?
selim
« Reply #31 on: September 12, 2008, 11:53:49 11:53 »
no,I programmed the pic with the PICkit2_FWv2.hex (PicKit2 modified firmware),
Here a link to a web site witch explain how make use GTP-USB Plus hardware with a PicKit2 modified firmware.
The name of the firmware : PicKit2Hybrid
the link : http://kcsoft.freehostia.com/pic.php
Best regards.
« Last Edit: September 12, 2008, 11:56:52 11:56 by selim » Logged
picbasic4
-Given: 24
-Receive: 30
« Reply #32 on: September 12, 2008, 12:00:08 12:00 »
I use GTBUSBplus + PICkit2_FWv2.hex (PicKit2 modified firmware)
but not work.. Cry
picbasic user  Smiley
newboy
-Given: 42
-Receive: 20
« Reply #33 on: September 12, 2008, 03:28:54 15:28 »
Picbasic4
Try the scematic from blueroom clone. It's work for me ...  Grin
-Given: 853
-Receive: 4420
« Reply #34 on: September 12, 2008, 04:19:58 16:19 »
or add the opamp to make a true pickit2 clone
goktug
-Receive: 23
« Reply #35 on: September 13, 2008, 09:02:43 21:02 »
LINK REMOVED
 Goktug you have been warned we do not like to see advertisement here for selling your own kit this was classed has a useless posting.
Next time I will log your warning
wizpic
« Last Edit: September 14, 2008, 08:14:16 20:14 by Wizpic » Logged
orange
-Given: 702
-Receive: 204
« Reply #36 on: September 27, 2008, 10:13:14 10:13 »
but not work.. Cry
Try to use with WinPIC800 software
http://www.winpic800.com//descargas/WinPic800.zip
kcsoft
-Receive: 68
« Reply #37 on: October 20, 2008, 09:23:03 09:23 »
It will surely not work with winpic800.
PicBasic4: follow the exact instructions found in pickit2hybrid package,and also try using pickit2 v2.40
pc software from microchip.com.
I'm using the pickit2hybrid and it works great.
But, still i advice you to use the real pickit2, you can get it for 30 bucks.
pama
-Receive: 28
« Reply #38 on: November 08, 2008, 01:20:05 13:20 »
a lot of pickit2 clones are on the web, but i found another one wich is realy close to the original version (just without the EPROMs).
But it's not tested by me!
good luck!
http://wattmep.tvn.hu/PICkit2_W_klon/PICkit2_W_klon.html
« Last Edit: November 08, 2008, 02:05:39 14:05 by bbarney » Logged
nickname
« Reply #39 on: November 12, 2008, 04:39:29 16:39 »
PicKit3 just come out.  Does anyone have any idea to make a clone of this new hardware?
pasanlaksiri
-Given: 144
-Receive: 59
« Reply #40 on: November 12, 2008, 05:27:34 17:27 »
This is my PICKIT2 Clone  Grin
remromgab15
« Reply #41 on: November 13, 2008, 01:11:11 01:11 »
There are no documentation available yet. Maybe after they release the diagram and firmware early next year.
pasanlaksiri
-Given: 144
-Receive: 59
« Reply #42 on: November 15, 2008, 02:51:44 02:51 »
with pickit2 and ICD2 beening cloned big time, I think they will not release diagram this time round.
But i think because of that cloning thing and selling those for cheap make microchip much more famous.
margo
-Given: 38
-Receive: 33
« Reply #43 on: November 15, 2008, 04:44:25 16:44 »
erm guys if you want a genuine pickit 2 just log into microchip direct ,select it £30, add the promo code epepic08
and get it for 30 pence +9.69 delivery all in £9.99, ive got 2 and just ordered a third!! comes with 44 pin 16f887, the code was printed in this months (nov) epe mag........
FriskyFerret
-Given: 513
-Receive: 360
Put it in, take it out.
« Reply #44 on: November 15, 2008, 09:09:47 21:09 »
Offer is only good for shipments delivered to UK according to EPE.
Mainul
-Given: 33
« Reply #45 on: April 11, 2009, 07:58:06 19:58 »
Dear Kcsoft,
I have downloaded 'pickit2hybrid' package and made the PCB following the schematic. I have also followed the instructions but I get the 'USB Device Not Recognized' message everytime I plug the programmer. I have checked many times for any error in the hardware, but didn't find any. Well, I Measured the Vpp voltge at IC2 11, 13 and 14 pins, I get about 13.3 voltage, which means part of the programmer is working (both hardware and software).
I would be really greatful if you could help me figuring out what I am doing wrong.
Mainul
jesse
-Receive: 101
« Reply #46 on: April 11, 2009, 11:53:23 23:53 »
   Well Guys
   Here's another one:
   http://sergiols.blogspot.com/search/label/PICKit2Clone
               Saludos
machine
-Receive: 34
« Reply #47 on: April 16, 2009, 10:40:00 10:40 »
Hi guys, the firmware is put after project mounted?
pasanlaksiri
-Given: 144
-Receive: 59
« Reply #48 on: April 17, 2009, 01:38:44 13:38 »
You hv to burn 18F with PK2 firmware first using some other programmer.
machine
-Receive: 34
« Reply #49 on: April 17, 2009, 11:04:03 23:04 »
Ok. I think pickit2 was enable for update. Any designs not have 24lc512, the pickit2 works?
thanks
