February 25, 2026, 09:58:01 21:58
Author Topic: a question.. about motor stepper  (Read 6293 times)
diego
« on: February 02, 2008, 08:23:15 20:23 »
hi,
i search a scheme and software for control a stepper motor 4 wire/ 6 wire with a micro pic16f627 or other similar.
thanks, diego
TomJackson69
-Receive: 63
« Reply #1 on: February 04, 2008, 04:36:08 04:36 »
Thre are lot of information about stepper motor at Microchip.com. If you search you will find exsamples and source codes. Here are some:
AN906 Stepper Motor Control Using the PIC16F684
microchip.com/downloads/en/AppNotes/00906B.pdf
AN822, Stepper Motor Microstepping with PIC18C452
ww1.microchip.com/downloads/en/AppNotes/00822a.pdf
Bipolar Stepper Motor Driver
Bipolar Stepper Motor Driver (Full Version). ... Message.
You can also search on the web for Stepper Motor Controller + PIC ... You will find other information on stepper motor too.
Good luck
Tom
ADDing:
Goto: http://www.cs.uiowa.edu/~jones/step/highlevel.html
You will find many informations (math + calculation) about stepper motor and controller. Simple  stepper motor driver for Bipolar and Unipolar.
Or goto: http://www.piclist.com/techref/io/stepper/linistep/index.htm
Here you will find a very simple but good Stepper Motor Driver with microstep. It use TIP122 to drive Unipolar stepper and it supports the standard modes:
200 step - full step
400 step - half step (with Full Torque)
1200 step - microstep 6th!
3600 step - microstep 18th!
It is open source code and give you schematic and PCB for you to build your own. Very good project, must see.
Tom
« Last Edit: March 08, 2008, 01:37:53 01:37 by TomJackson69 » Logged
Con Rong Chau Tien
MariusC
« Reply #2 on: February 10, 2008, 03:25:15 15:25 »
Hi Diego
here you can find many resources about stepper motor control
http://www.discovercircuits.com/S/stepper.htm
hosmis
-Given: 373
-Receive: 244
« Reply #3 on: February 10, 2008, 06:09:53 18:09 »
http://pminmo.com/
