March 10, 2026, 01:46:02 13:46
Author Topic: Computer motherboard repair (servicemanuals and schematics)  (Read 34112 times)
Rick101
« on: January 30, 2008, 10:50:50 22:50 »
ISO-image CD from China "Motherboard repair" (120MB)
Part 1 http://w15.easy-share.com/1698572021.html
Part 2 http://w15.easy-share.com/1698567721.html
Part 3 http://w15.easy-share.com/1698562211.html
motherboard schematics coming soon.
Posted on: January 30, 2008, 01:00:31 13:00 - Automerged
Motherboard from Gigabyte:
GA-60XT http://w15.easy-share.com/1698695721.html
GA-7ZX http://w15.easy-share.com/1698695731.html
GA-8TM http://w15.easy-share.com/1698696621.html
GA-K8NF9 Ultra (block-scheme) http://w15.easy-share.com/1698696631.html
to be continued...
shobits1
-Given: 15
« Reply #1 on: January 31, 2008, 06:41:41 18:41 »
have any one have the scheme of the Gigabyte motherboard the X38-DQ6, or at least the the cpu power block of this motherboard.
Rick101
« Reply #2 on: January 31, 2008, 09:07:58 21:07 »
No, i have no it. But this no problem. What kind of PWM IC installed on this motherboard?
Posted on: January 31, 2008, 09:37:13 21:37 - Automerged
Motherboards from TopStar:
H915G http://w15.easy-share.com/1698765621.html
HKT400AL-KT600DL http://w15.easy-share.com/1698765631.html
HKT400ARL http://w15.easy-share.com/1698765641.html
P21i http://w15.easy-share.com/1698765651.html
TM-845G http://w15.easy-share.com/1698765661.html
Rick101
« Reply #3 on: February 02, 2008, 03:26:09 15:26 »
Sorry, i have very slow connection with rapidshare Sad
Albatron PX865PE ProII http://w15.easy-share.com/1698903871.html
pl4tonas
-Given: 330
-Receive: 196
« Reply #4 on: February 03, 2008, 09:21:48 09:21 »
A very common fault on motherboards is on defect electrolytic capacitors.
In general the 1000uF capacitors used in power line filtering are dryied out or almost ready to blow.
By replacing them, the motherboard is functional again.
Common faults for this problem are, random resets, not proper power-up or crashes.
Rick101
« Reply #5 on: February 09, 2008, 11:55:18 23:55 »
Intel referrence schematics:
i386 http://w15.easy-share.com/1699520099.html
i486 http://w15.easy-share.com/1699520100.html
Plumas533 chipset http://w15.easy-share.com/1699520101.html
E7500 chipset http://w15.easy-share.com/1699520102.html
E7501 chipset http://w15.easy-share.com/1699520103.html
i430HX chipset http://w15.easy-share.com/1699520104.html
i430TX chipset http://w15.easy-share.com/1699520105.html http://w15.easy-share.com/1699520106.html
i430VX chipset http://w15.easy-share.com/1699520107.html
i440BX chipset http://w15.easy-share.com/1699520108.html http://w15.easy-share.com/1699520110.html
                        http://w15.easy-share.com/1699520111.html http://w15.easy-share.com/1699520112.html
i440BX Dual-Processor http://w15.easy-share.com/1699520109.html
i440GX chipset http://w15.easy-share.com/1699520113.html
i440LX chipset http://w15.easy-share.com/1699520114.html
i440MX chipset http://w15.easy-share.com/1699520115.html http://w15.easy-share.com/1699520116.html http://w15.easy-share.com/1699520117.html
marty.markoh
-Given: 192
-Receive: 433
Everything must B explored!Remember what U see!
« Reply #6 on: July 25, 2008, 12:42:02 12:42 »
Is anyone want 2 share schematic for motherboard P6BX7(or P6VBX7 or P6ZX7-all 3 code is writed on board)-pc info:Intel Celeron 367Mhz,160Mb RAM AND SC58P -pc info:PENTIUM(R) 75MHz,64 Mb RAM,Sys MEM 640Kb?Thanx in advance....
marty
 Smiley
« Last Edit: July 25, 2008, 12:45:12 12:45 by marty.markoh » Logged
sheriefaly
« Reply #7 on: October 19, 2008, 07:52:35 19:52 »
please dose any body have laptop Dell vostro 1500 motherboard drawing
thanks in advance
FriskyFerret
-Given: 513
-Receive: 360
Put it in, take it out.
« Reply #8 on: October 19, 2008, 08:26:39 20:26 »
Look for bulging tops or a dome on top of the cap. This is an indicator of incipient failure due to gas build-up inside the aluminum can. The electrical value of the cap has probably degraded far beyound the normal loose tolerances for an electrolytic cap. The indented lines on the top are to try to cause the can to fracture in a controlled way and split open the top of the cap instead of exploding the whole cap like a firecracker. In my experience this doesn't usually happen and the whole cap blows up with a loud bang and you smell that 'electrolytic cap death' smell.
Rick101
« Reply #9 on: November 12, 2009, 08:24:14 08:24 »
Refreshed links.
386
http://depositfiles.com/files/zvx0xwwsj
486
http://depositfiles.com/files/fixu6l7gz
e7500
http://depositfiles.com/files/48ql8rf1s
e7501
http://depositfiles.com/files/prpv8cez1
i430HX
http://depositfiles.com/files/3aueynt2l
i430TX
http://depositfiles.com/files/js0uer5cl
http://depositfiles.com/files/32mmsywak
i430VX
http://depositfiles.com/files/59phzhniv
i440BX
http://depositfiles.com/files/iwr806b93
http://depositfiles.com/files/rktfqiyhd
http://depositfiles.com/files/r9k7e88dt
http://depositfiles.com/files/7mkvafgcf
http://depositfiles.com/files/py2jnn91t
Rick101
« Reply #10 on: November 13, 2009, 05:51:56 17:51 »
i440GX
http://depositfiles.com/files/g7462ad3w
i440LX
http://depositfiles.com/files/5ieyqbzol
http://depositfiles.com/files/cfknw25uq
i440MX
http://depositfiles.com/files/m7587simo
http://depositfiles.com/files/zvrldyt7n
http://depositfiles.com/files/u7lkqe0o9
thecic
« Reply #11 on: November 18, 2009, 10:44:16 22:44 »
I fully agree with pl4tonas, the most common reason for a failing motherboard is the electrolytic capacitors, normally the electrolytic capacitor close to the CPU and PSU fail earliest, but also other electrolytics on the motherboard use to fail.
Another thing to bear in mind when the electrolytic liquid comes out it can short or disturb some functions if it comes on the motherboard PCB, so make sure to clean thoroughly!
I have repaired motherboards with success and it's 95% a matter of just changing the electrolytic capacitors.
