April 19, 2025, 02:37:18 14:37
Pages: 1 2 [3] 4 5
Author Topic: GTP-USB [plus] programmer firmware req.  (Read 75451 times)
Vague
-Given: 703
-Receive: 29
« Reply #50 on: August 23, 2006, 04:05:32 16:05 »
Has anyone got the firmware file for the GTPUSB PLUS programmer that SakCyb so kindly posted the schematic for. I have tried the GTPUSB firmware and it does not seem to generate the programming voltage.
Thank you
SakCyb
-Given: 47
« Reply #51 on: August 23, 2006, 05:49:28 17:49 »
Vague
It looks like the only way you are going to get this one to work is to order the pre-programmed PIC from Sisco, he was off line for some time but is back at a new website:
http://www.winpic800.com/
If I was you I'd try this one posted in another thread, it looks good and is free:
http://www.sprut.de/electronic/pic/projekte/brenner8/index.htm#einleitung
Sorry I have not better news for you
SakCyb
Vague
-Given: 703
-Receive: 29
« Reply #52 on: August 26, 2006, 07:34:34 07:34 »
thank you for the information Ihad a look at the winpic website. he is now selling the PCB chip and firmware as one package and is not selling the firmware separately. I liked the look of the Brenner8 circuit on www.sprut.de. Ihave started building it and I'll let you know how it works out.
Thanks again
Vague
-Given: 703
-Receive: 29
« Reply #53 on: August 28, 2006, 11:00:28 11:00 »
Hi I built the brenner8 programmer. It works fine. The circuit board is well laid out and easy to solder. He has kept the clock and data lines well separated and so reduced the oppotunity for cross talk problems. I have programmed a 18f25550,12f675,16f877,16f877a and a 16f84 with it successfully although for the 877 and the f84 I had to use the ICSP connector.the designer deserves congratulations on his hard work.
mizk_electro
« Reply #54 on: September 04, 2006, 02:22:34 14:22 »
Quote from: Vague
Hi vogue,
If you dont mind, could share the info & source (software & schematic & pcb ) with us ? ... so hopefully we dont make a similar  mistake Smiley.
Thnks.
Vague
-Given: 703
-Receive: 29
« Reply #55 on: September 04, 2006, 06:24:14 18:24 »
Hi mizk electro
All the up to date stuff is available from the website www.sprut.de. Look under brenner8. Everything is there. If you cant speak German do a search on Google and get google to translate the page. this is what I did.  If you have problems downloading it let me know and I will post thefiles.
mizk_electro
« Reply #56 on: September 05, 2006, 03:30:50 15:30 »
Thanks ... I will try later ... Smiley
acat_lm
-Given: 73
-Receive: 128
« Reply #57 on: December 18, 2006, 05:44:36 05:44 »
USB ICD2 Clone.
Link:
http://www.icd2clone.com/w/index.php?title=Main_Page&redirect=no
« Last Edit: December 18, 2006, 05:46:44 05:46 by acat_lm » Logged
charudatt
-Given: 53
-Receive: 70
« Reply #58 on: February 13, 2007, 05:29:24 05:29 »
HEllo,
Having problem running the GTP-USB on Vista. the Programer does not get recognised.
Any of you'll having the same problem or any solution.
juliano barcik
« Reply #59 on: May 08, 2007, 04:29:16 04:29 »
link for download GTP-USB [plus] programmer firmware
http://www.4shared.com/file/13731279/7bb84f76/GTP-USB_Programer.html
spasbyspas
-Given: 736
-Receive: 366
« Reply #60 on: May 08, 2007, 06:33:33 06:33 »
Thank you!!!
iphone
-Given: 115
« Reply #61 on: May 08, 2007, 03:03:41 15:03 »
Are you sure this hex for GTP-USB [plus] programmer firmware. If I'm not mistaken, its GTP-USB Lite Programer.
Can you use this firmware with latest Winpic800 latest version ?
ducky2002
« Reply #62 on: May 10, 2007, 12:06:23 00:06 »
if you load the hex and watch the eeprom area you see that it is the firmware revision 3.55...also known as  gtp usb summer edition...it a pro version...but the firmware will not work with the latest winpic800...it will only work with winpic800 v 3.55 perhaps with v3.60. i've build it a long time ago...it works good but my brenner8 from www.sprut.de is better...and completely free...
iphone
-Given: 115
« Reply #63 on: May 11, 2007, 07:29:31 19:29 »
I'm also build it ... it's good so far but not brenner8 at the moment  Grin
What is diffrent between this 2 programmers ?  Wink
Thanks in advance.
GreenGiant
« Reply #64 on: August 12, 2007, 02:00:57 02:00 »
Has anyone tried the brenner8 udner windows vista ?
(dont tell me 'it should work' only say if youve actually tried it and it worked)
adrian
-Given: 27
-Receive: 14
« Reply #65 on: August 31, 2007, 02:06:22 14:06 »
In my opinion, melabs U2 Programmer is the best. It can be found at http://melabs.com/products/usbprog.htm.
However there is no clone for this circuit. There are review that brenner8 is quite good. But i've never build one
yet. Coz its not in english. Haha. Grin I'm using EPIC and i'm very satisfied with it up to now.
Ret12_12
-Given: 104
-Receive: 32
« Reply #66 on: September 01, 2007, 09:00:00 21:00 »
And PICKit 2 also. Cheap and has USB and support all the microchip pic
-Given: 841
-Receive: 4367
« Reply #67 on: September 04, 2007, 01:03:10 01:03 »
I suport best usb programmer as the pickit 2.
It will auto program your pic chip on update of hex code.
just tick the box Smiley
also you can use the pickit 2 as a USB to Serial interface lead.
see http://www.picbasic.org/forum/showthread.php?t=6782
Pickit 2 now has a Auto Inport Hex + Write.
This works like a charm leave the box ticked and Pickit 2 will auto load your code as it's complied in PDS.
An other thing you can do with Pickit 2 is you can use it as USB to Uart coms.
charudatt
-Given: 53
-Receive: 70
« Reply #68 on: September 05, 2007, 02:05:16 14:05 »
Any idea which hardware will program a 18F6722 ?
I have a JDM type programer and WinPIC800 3.61.
The software does not recognise the device.
Any help ?
terval
-Given: 15
« Reply #69 on: September 05, 2007, 11:55:07 23:55 »
I tried GTP USB and Brenner ,GTP it´s ok but Brenner doesn´t work with dspic30F6014A,using V.10,pic 18F all fine.
walteca
« Reply #70 on: September 06, 2007, 06:49:53 06:49 »
Other alternative.
http://www.freewebs.com/eclip-se/inicio.html
Thx
iphone
-Given: 115
« Reply #71 on: September 06, 2007, 09:42:30 09:42 »
Do you make it ?  successful ? .... what type of  PIC being support ?
walteca
« Reply #72 on: September 06, 2007, 06:51:44 18:51 »
16 and 18 PIC family
ds30   dsPIC family
http://www.freewebs.com/eclip-se/hardware.zip
http://www.freewebs.com/eclip-se/firmware.zip
http://www.freewebs.com/eclip-se/software.zip
I dont make it.
Excuseme for my bad english
-Given: 405
-Receive: 545
« Reply #73 on: September 08, 2007, 05:44:53 17:44 »
You people who keep asking this must have an awful lot of spare time and love frustration?
Just buy a Pickit2 and you will never be asking which programmer will program such & such chip# again because it will do them all and is constantly being upgraded by Microchip.I 've built 5 differant programmers,why you ask because I needed all 5 to program just to do the everyday pic's everybody use's,now I don't have that problem.you can't beat the price for what you recieve in the package so quit spending all your time making programmers that just don't meet all your needs.then maybe you'll have more time to make the project instead of figuring out how your going to program the chip.
I wish I had all the time and money back I've spent screwing around so called cheap and easy programmers,cheap yes, easy yes, useful not really.
htteam
« Reply #74 on: September 13, 2007, 06:45:19 18:45 »
Another one USB look like PIC LIT 2 clone. See info in
h**p://www.futurashop.it/allegato/7100-FT650M.asp?L2=PROGRAMMATORI%20E%20DEMOBOARD&L1=SCATOLE%20DI%20MONTAGGIO&L3=PROGRAMMATORI%20PIC&cd=7100-FT650M&nVt=
"Semplice software di programmazione PICKit2" - This programmator use pic kit 2 programming software.
Pages: 1 2 [3] 4 5
