-Given: 405
-Receive: 545
« Reply #25 on: March 21, 2006, 10:25:49 22:25 » |
Yes your right about the wife part,mine keeps asking when I'am going to invent something useful and I'am wondering too,:D only she don't know that part:) While I have your attention how do i place smd parts on the bottom of the board in eagle i know how to change the trace's but i can't move the part.
SakCyb
-Given: 47
« Reply #26 on: March 22, 2006, 12:01:48 00:01 » |
BB I am afraid I have not done a single smd board, but I have started a smd version of the GTP-USB Plus as a starting attempt, it is now really time to switch over. All my electronic buddies say once you've made your first smt board, then you will never use through-hole-pin components again. Also remember we here in Africa are a little (actually more than a little) behind technology. So you are allowed to have a little chuckle about my reply. But to try and answer your question, use the mirror function (Edit - Mirror or the Mirror button just below Move on the LH toolbar). As soon as you then click on a smd part then the connection pins will turn blue and the part will mirror, meaning that the part is now on the bottom layer. Hope I have it right, let me know if it worked in your design. Please do not ask me how to make parts in Eagle, I have not tried that, in fact I am no expert with the program at all, only been using it for the past 3 months for small designs. SakCyb
« Last Edit: March 22, 2006, 12:05:47 00:05 by SakCyb »
-Given: 405
-Receive: 545
« Reply #27 on: March 22, 2006, 11:04:13 23:04 » |
Thank's I've used it before but couldn't remember how to do it because i haven't made a double sided board in months .It will definately help my design switching some parts over to the other side.
bb
mizk_electro
« Reply #28 on: June 28, 2006, 04:59:50 16:59 » |
Yes, not for plus. I just build the GTP-USB board base on your attachment, and program the hex code into 18F2550 with JDM2 Programmer. I plug the 18F2550 into GTP-USB board & run winpic800 and select gtp-usb lite (with USB connection) and also select gtp-usb plus (with usb connection) but DOESN'T work. It just cannot detect the hardware. Is it (your attachment) is proven working ? Any help / any suggestion .... appreciated very much.
SakCyb
-Given: 47
« Reply #29 on: July 11, 2006, 05:10:19 17:10 » |
mizk_electro
Did you use my Eagle layout (Post #10) to make your PC Board. I made two of these boards without any problems, but I ordered the pre-programed 18F2550 from Sisco. I am not sure if this layout works with the hex code 8051 posted.
SakCyb
LazBoy
-Given: 78
-Receive: 25
« Reply #30 on: July 12, 2006, 06:30:42 06:30 » |
I have been try to contact with Sisco for to buy a firmware chip but I did not get any response. Are there any rules for this ?
SakCyb
-Given: 47
« Reply #31 on: July 12, 2006, 05:45:18 17:45 » |
No rules, just waite, he sometimes take a little time to respond :p
mizk_electro
« Reply #32 on: July 12, 2006, 10:10:03 22:10 » |
mizk_electro
SakCyb SakCyb, Thks for reply.Actually, I built one board using your circuit(v 1.3) and program the 18F2550 with hex from 8051.Result not detect??? I'm also built one board using 8051 attachment but also not working(but my laptop detected it and request driver & install drivers succesfully).It do not program/detect any PIC chip  I'm not buying 18F2550 from Sisco as I have some blank 18F2550 (free sample from microchip  ). If you succesfull built it (USB board with blank 18F2550) and using the hex from 8051, hopefully you will share the info with us,would you? In winpic800, what the settings you use? if possible can you make a snapshoot of the setting and post it here or in rapidshare? Thks for info
mizk_electro
« Reply #33 on: July 12, 2006, 10:22:03 22:22 » |
I might still build the lite ver. just for love of tinkering  I just can't spend $50 on a chip especially when I already have 6 blank ones sittng here. bb bbarney, Any success with lite version? Would you share the info/guide/experiences on how to build it? I'm using laptop(DELL Inspiron 6400) without any serial port.I succesfull built JDM2 Programmer (and using it on my friend Desktop PC) but it not work with my laptop(using USB to serial converter)  . So any suggestion/guides to built pure USB programmer ? thks for any info/guides.
-Given: 405
-Receive: 545
« Reply #34 on: July 12, 2006, 11:22:34 23:22 » |
Funny you should ask
I put it on the back burner because i had to order a few part's for it and I was waiting to have enough other stuff to make ordering worth my while,but i just ordered the parts today so it will be a few days before i can say anything about it.made the board already so i just gotta wait for parts
SakCyb
-Given: 47
« Reply #35 on: July 14, 2006, 05:00:11 17:00 » |
mizk_electro
If I go to a electronic shop I will get a blank PIC18F2550, program the Hex form 8051 in and swap the PIC from Sisco with this one and see if I get it to work, but please do not expect this to happen tomorrow, but I will do it. Is that ok? SakCyb
-Given: 405
-Receive: 545
« Reply #36 on: July 16, 2006, 06:23:36 18:23 » |
built SakCyb's ver 1.3 board and it's not detected at all on a desktop pc.I tried every piece of firmware i could find on the net with no luck.At least you got windows to detect it mizk_electro so your doing better than me:eek: don't know if i want to try and figure it out or just forget it because i've got that Pickit2 programmer
mizk_electro
« Reply #37 on: July 17, 2006, 04:15:11 04:15 » |
mizk_electro
If I go to a electronic shop I will get a blank PIC18F2550, program the Hex form 8051 in and swap the PIC from Sisco with this one and see if I get it to work, but please do not expect this to happen tomorrow, but I will do it. Is that ok? SakCyb SakCyb, Your kindness, very very much appreciated.Better late than never  .Take your time & do it whenever you free. Thanks a lot dude.
mizk_electro
« Reply #38 on: July 17, 2006, 04:26:52 04:26 » |
built SakCyb's ver 1.3 board and it's not detected at all on a desktop pc.I tried every piece of firmware i could find on the net with no luck.At least you got windows to detect it mizk_electro so your doing better than me:eek: don't know if i want to try and figure it out or just forget it because i've got that Pickit2 programmer bbarney, 1. I tried SakCyb v1.3 with hex (from 8051) ... it'not work & also not detected by WinXp home edition. 2. I built board (using hex & sch from 8051) .... detected by winxp home & installed the driver succesfully but cannot program/dont detect pic. 3. I built board (using gtp lite sch(got from net) & hex (by 8051)) .... detected by winxp home but cannot program/dont detect any pic. But the sch in no 3 almost similar with sakcyb v1.3 ... hmmm dont know what happen:confused: If you make the board with either using sakcyb 1.3 or from 8051, hopefully you can share the info with us.
mizk_electro
« Reply #39 on: July 17, 2006, 04:41:30 04:41 » |
bbarney,
If you make the board with either using sakcyb 1.3 or from 8051, hopefully you can share the info with us. Hmmmm .... dont know what to do  maybe I need to get my old deskstop from hometown & use serial port JDM2 programmer to program PIC ... or follow bbarney footstep ..... :cool:
-Given: 405
-Receive: 545
« Reply #40 on: July 17, 2006, 05:37:48 17:37 » |
I have not made any progress getting it to work,but I'am still trying
-Given: 405
-Receive: 545
« Reply #41 on: July 18, 2006, 03:11:26 03:11 » |
mizk_electro
« Reply #42 on: July 19, 2006, 05:28:13 05:28 » |
Thks for the link.
-Given: 405
-Receive: 545
« Reply #44 on: July 19, 2006, 06:34:42 18:34 » |
Thank's Mizk_Electro I might build this ver. on the weekend and give it a try
zerro
-Given: 22
-Receive: 19
« Reply #45 on: July 22, 2006, 11:59:36 23:59 » |
Can somebody upload again the 4 zip archive from the first page  (all the zip archives are corrupt ... 0 bytes). Thanks!
Don't follow me !!! ... i'm lost too ...
SakCyb
-Given: 47
« Reply #46 on: July 23, 2006, 07:15:55 19:15 » |
Zerro Hope this is one you are looking for. The PC Board has a GND copper pour, so remember to hit the Ratsnest button once it's open in Eagle. SakCyb
« Last Edit: July 23, 2006, 07:29:26 19:29 by SakCyb »
zerro
-Given: 22
-Receive: 19
« Reply #47 on: July 24, 2006, 10:26:52 10:26 » |
Thanks @SakCyb ... And someone have the hex (firmware) files from attachments on the firsyt page fron @8051 Thank you!!!
mizk_electro
« Reply #48 on: July 29, 2006, 05:09:15 17:09 » |
Thanks @SakCyb ... And someone have the hex (firmware) files from attachments on the firsyt page fron @8051 Thank you!!! As per request
zerro
-Given: 22
-Receive: 19
« Reply #49 on: July 29, 2006, 10:21:11 22:21 » |
Thank you!!!
